Support for Fuji Imvac engines
Here are some 46cc on ebay for $33.00 shipped, Where are the 65cc located.
http://www.ebay.com/itm/390805002207...%3AMEBIDX%3AIT
Milton
Milton
BC
This was 2010. Used the RCExcel unit and and sensor. TBH, it never worked to my liking. Made it very tough to start, no matter where the sensor was positioned, and never gave any benefit. Had the whole set-up...template, protractor, buzzer, popcorn popper... Advance, retard, centered...never could get it reliable. Finally ditched it and went back to the stock. Also, for clarity, I never sent the unit back in to have it checked.
I only tried it to see if it would improve anything. It improved my forearm size and pulse rate.
They are timed at about 15 degrees before top dead center, You can get it to crank with a starter but the timing will not advance enough to get the engine running right.
You need a sensor and bracket that will allow you to time the engine at 28-30 degrees before top dead center.
I have been making them for over four years.
http://www.rcextremepower.net/FujiIgnitions.html
Milton
