Saito Fc 14 Gas Engine
My Feedback: (10)
I have a Saito 100 glow engine and I replaced the muffler with a straight stainless steel pipe. I kept the 90 degree elbow that came with the motor and drilled and tapped a barbed fitting for fuel tank pressure. This setup has worked great and is not loud. It also has not affected performance at all.
I am looking to purchase the new line of Saito gas engines and I am wondering can I duplicate the same setup on the gasoline engine? Do the gas engines need a pressure line? Would the straight pipe be an issue? Would it perfect performance?
Rye
Rye
