Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
Reload this Page >
UMS Radial Engines. Who's got one and are they any good?
Old 08-08-2021, 02:14 AM
ptdan
Hi hi guys
A question, i have the ums 75-5, it has run about 2 liters. But it suddenly stopped, cant start it again. I found out, it only gets fuel in the lower cylinders. Any ideas??? And im using a Emotec fuel pump.
Dan
Old 08-08-2021, 05:12 AM
n8622t
My Feedback: (8)
It sounds like it’s either the ignition or the pick up sensor. If the bottom cylinders get fuel then so will the top cylinders. Make sure the battery is healthy also, as well as a good functional switch. I’d say you have an electrical problem
ptdan (08-08-2021)
Old 08-08-2021, 06:18 AM
ptdan
Thanks Jimmy, i have sent a mail to bigplanes. Thats where i bought the ums, it should be a warrenty problem.. I can not be the carb?????? And there is sparks.
Old 08-08-2021, 06:47 AM
n8622t
My Feedback: (8)
Yes If you have fuel in the cylinders then it has to be spark
Old 08-08-2021, 07:22 AM
ptdan
The sparkplugs are ok, and give a spark when i turn it. When they are out, but it is only one cylinder that gets fuel.. Lets see what bigplanes says
Old 08-08-2021, 08:29 AM
  #31
n8622t
My Feedback: (8)
Good idea….warranty is always good
Old 08-15-2021, 06:46 AM
  #32
ptdan
Hi again
I found out why it would'nt start or run The y festo for pressure to the carb, was blocked with some plastic.. Maybe from the nylon, but it works.. Happy days....
Dan
Old 08-15-2021, 07:23 AM
  #33
DaleD
Originally Posted by ptdan View Post
Hi again
Dan
This is GREAT news. Happy to know your happy days have returned.
Feel free to share a video of your motor in operation. There is no better feeling in the hobby than that derived experiencing a multi-cylinder 4-stroker.
DaleD
Old 08-15-2021, 07:59 AM
  #34
n8622t
My Feedback: (8)
Next install is underway…upgrade from Zenoah GT-80 to the UMS 5-180cc on my 1/3 scale BlasaUSA N-28
Old 08-15-2021, 08:01 AM
  #35
n8622t
My Feedback: (8)
Previous install of the UMS 5-125cc on a TopRCModels FW190
Old 08-15-2021, 08:07 AM
  #36
n8622t
My Feedback: (8)
Hi again
Dan
it’s getting fuel but not enough…good find!! It saves you from shipping it in😃
Old 09-20-2021, 06:32 AM
  #37
marksp
My Feedback: (9)
marksp's Avatar
Decided to go with the Black Star 5-250v3 bundled with a model from Tomahawk. The Black Star is essentially a Tomahawk branded UMS radial (virtually identical if not the same as the UMS 5-260). This is my first UMS engine but am very familiar with Moki and Saito radials.
Happy to share engine gets better every flight! Currently collecting & triaging telemetry data from PowerBox CORE - Max RPM during this flight was 4630 turning SEP 32x14 Wilga prop.
Engine starts easy, pulls strong and sounds fantastic!
Old 10-27-2021, 11:47 AM
  #38
DaleD
Default APS PowerFuel RX Pump on Taranis
Good day,
Anyone using a FrSky Taranis on OpenTX to fly their multi-cylinder 4stroke engine with the APS PowerFuel pump powered model? I’m hoping to get some help for my UMS 5 75.
I would specifically like to know the programming in the radio used to ensure appropriate fuel flow from idle to full throttle.
DaleD
Old 10-27-2021, 11:58 AM
  #39
1967brutus
Isn't the carburettor supposed to take care of that, and the pump to be run at constant speed (on/off switch)?
I think you can control the pump from the transmitter, but you could just as well have the pump run when the ignition is on: Priming should not be an issue with an electric pump and that way you cannot flood the engine unless you leave the ignition on without starting it, which one should never do anyway...
Old 10-27-2021, 12:23 PM
  #40
DaleD
When I bought the pump it was suggested that I programme for 5% flow at idle and around 40% at full throttle.
I have tried one approach which worked for a while but now there seems to be an issue which I need to troubleshoot and resolve. If it is that I do not need to have the pump operate based on throttle position I would be more than happy to just use an on/off switch.
With an on/off operation, what level of output is suitable? I am figuring that MAX output maybe too high.
Thanks for responding
DaleD
Old 10-27-2021, 12:30 PM
  #41
1967brutus
I can't help you there, I was assuming that you would have a fuel pump with a fixed speed anyway, had not heard of "controllable" fuelpumps on gassers before...
Last edited by 1967brutus; 10-27-2021 at 12:45 PM. Reason: Sorry... "speed" instead of "flow"
Old 10-27-2021, 12:49 PM
  #42
n8622t
My Feedback: (8)
My pumps run constant speed with a pressure valve that allows fuel to flow back to the tank, the engine only uses what it needs
Old 10-27-2021, 01:16 PM
  #43
DaleD
Originally Posted by n8622t View Post
Previous install of the UMS 5-125cc on a TopRCModels FW190https://youtu.be/gtSQG-wZ5Cc
Did you note a change in the tune of the engine with the pump installed? It appears my engine has gone quite rich.
DaleD
Old 10-27-2021, 01:25 PM
  #44
DaleD
Thanks for responding.
Wondering about your set up. What pump are you using? With the constant speed operation, are you at maximum output?
DaleD
Old 10-27-2021, 04:36 PM
  #45
n8622t
My Feedback: (8)
Sure, the pump is on or off running on 4.8v. The pump is from Micropumps and the valve is from USPlastics
Old 11-09-2021, 05:04 PM
  #46
GlennM
Good day,
DaleD
Hi, have you tried setting up the pump on a spare channel (lets say Ch 6), assign Ch 6 to the throttle and set the pump (throttle) end points at what you think is 5% and 40% (something like -90% for 5% and -20% for 40%) you could also have it assigned to a switch either the ignition kill or a separate switch if you want to turn fuel off whilst engine is running.
Regards Glenn
Old 11-10-2021, 06:34 AM
  #47
DaleD
Regards Glenn
Thanks for the suggestion.
Based on other suggestions from other UMS engine operators, I have decided to operate the pump on an on/off principle using the same switch for the ignition. I had to adjust the sub-trim in the radio to achieve the desired operation.
Regards
DaleD
Old 09-13-2022, 08:16 AM
  #48
LtMash1A
I think radial engines have more torque, but how do they compare with traditional single cyl. engines. For example, if the recommended engine is an 80cc for the plane, what UMS radial would be appropriate assuming the cowl will accommodate either one?
Old 09-13-2022, 08:22 AM
  #49
LtMash1A
Was there adequate room in the cowl for the 125?
Old 09-13-2022, 09:25 AM
  #50
badangle
Don't forget to factor in the weight difference when doing comparison....also reliability, cost.
yes radials look and sound great, but MY personal experience tells me unless you have veryDeep pockets and lots of patience beware, messing around with radials caused me grief.
evolution 7-77 glow radial and moki 5 cyl 180 gas radial.
bottom cylinders get fouled up and fuel distribution to each cylinder also common issue.
setting valves also complicated.
Don't get me wrong, if I ever hit the lottery I would get another Moki but
