DLE-111 Ver 2 won't fire
As the title states my DLE-111 won't fire. I had it running yesterday trying to tune the low needle and was doing a full throttle run, then back to idle. Engine quit and have not been able to start it since or even get a pop.
I have fuel through the carb, plugs were in fact wet when I pulled them out, they are NGK. I then put plugs back into the boots and rotated past the hall sensor, I get spark to both plugs but would not say it is super strong. Battery was freshly charged.
I then tried with one plug in the engine and one out with the plug in the boot and rotated past the sensor, plug out had spark but looks to me to be weak. Interestingly I got a slight kick from the other cylinder.
Can I assume hall pick up sensor is ok?
Can I assume the battery is ok? Reads 7.4v LiION pack.
Ignition module stuffed?
There is no easy answer. What pops into my head is operator error ( badly flooded not tuned well ). The plugs should not be wet. Should be a nice air fuel mixture in each cylinder. Starting and tuning are not always easy. From your description nothing seems wrong but the tune.
I don't know what you have available, Faced with this I would do the following:
1 remove the plugs and dry them
2 set each of the needles to 1 1/2
3 with the plugs out and ignition off and throttle wide open, spin the engine over with a starter or something ( any starter will spin a DLE 111 with the plugs out and no compression ) for 15 or 20 seconds to dry out the engine ( it will be well primed though).
4 replace everything and turn on everything with the throttle set at a high idle
5 try to start the engine No choke needed at this start
6 if engine starts and runs, re-tune high speed needle first
7 then the low speed needle
hope you find this useful no insult intended
These are the fromenco 7.4V packs, not the normal 7.6v LiION packs I tried it on 2 different packs, same result and reason for that will be apparent as you read further.
ok problem solved. Tuns out the timing ring had come loose, will need to reset the timing. I have the timing kit just have wrong piston stopper. Mine is for the smal glow plug sized heads not CM-6 size.
Reset timing yesterday just using a ball driver to feel for TDC, will re-check it this morning once some coffee kicks in.
thanks for all the comments.
Ah yea, the DLE magnet is drilled and fixed via key in the hub to the crank . No timing ring.
Seems your magnet is not this simple stock set up. Your timing ring is after market.
