OS Gemini Twin Rear Walbro Gas Conversion
#51
This is a standard Walbro carb off of the RCGF 15cc gas engine. I just happened to have taken a couple pics of it this morning. I even took a venturi shot. I’d estimate the venturi to be .375 give or take a few thousandths. I took a pic of the serial number.
I cannot overstate how great this carb is working on the Gemini 160. It is well behaved in every respect. I'm so happy!
#53
How does the Xoar compare to the APC wideblade series? I run an APC 18 x 6 Wideblade on my ASP 160 and it does about 7400 on the ground, 8200 in the air and pulls stumps. I use mine for glider towing.
#54
I had used my first rascal (with this gemini - not converted to gas yet) for glider tow. That was a lot of fun!
I will say this about converting a glow engine to gasoline: horse power is going to be reduced slightly. However, I can't really tell much difference with my conversion so it can't be much. She puts out a ton of power.
#55
Since AFAIK the output in HP is not stated for both your OS boxer as well as my ASP, I don't know either what the exact reduction in power is for this engine. the only indication I have is that the vendor that sold me my ASP told me what he had seen these engines do on glow fuel (about 2,3 hp between 7500 and 8K), and apparently the numbers he gave me were "straight from the box" and before break in, because although initially mine was producing significantly less than that (first runs showed something like 1,7 hp), after about 15~20 runhours it turned out that it only missed that 2,3 hp by about 0,1...
According to my prop-calculator (Pe reivers' propcalc), mine puts out in the neighbourhood of 2,1~2,2 if tuned for peak on the ground. (I tried different online calculators, with virtual identical results by the way).
That is not a tune that is usable for flight (too lean) but in "flight tune" there is still about 1,9~2 hp on the ground, which increases in the air due to unloading. For transparency: I tune about 300 RPM rich from peak for flight.
My guess is there is well over 2,2 HP availlable in flight. But that is just that, an educated guess. I have not yet found a propcalculator that can work with "in flight RPM" so there's no way to be certain...
FWIW: I have run a converted OS FT160 side by side with my converted ASP (I did the conversion on both, so there are no significant differences in the method of conversion), and there is no real measurable difference in performance. The OS is (much!) nicer made, but not measurably stronger or weaker in performance. Can't comment on the durability differences, my ASP shows zero deterioration, neither does my clubmate's OS, but he flies his a lot less than I do mine, so no way of telling either way.
Your engine might easily pick up a couple of hundred RPM by the way, when the running surfaces re-mate using the different lubricant. That is at least invariably my experience with engines that were run on glow fuel previous to conversion, that they pick up ever so slightly after 5 or 10 hours of operating time, especially if the glow fuel used to contain significant amounts of Castor oil. Apparently the type of lubricant has some effect on the mating of the running surfaces, IDK, but I see that slight gain every time again.
#56
The power differences are far less noticeable when flying typical, high drag type planes.
Very noticeable on the more spirited, sport and pattern type planes.
Even more pronounced in both types however when CDI ignition is used with the methanol, even when the nitomethane percentage is rolled back.
The run time takes a boost as well.
A fellow RCU member did some real fine, well documented work at adapting Saito glow engines to CDI. With proper tuning he was getting real power gains and substantial boosts in run time.
#57
I'm really enjoying this line of discussion but I have to admit that I'm much less analytical about this conversion. The C&H doesn't have a tach lead and I don't have a hand tach so I can't even tell you the R's! Since I fixed every main concern I had with running on glow fuel the only real concern I have now is how much power did I lose and will it affect the durability. . . .
I've been flying it quite a bit lately (with the Xoar 18x6) with the mixture just a tic off of max lean - that's where it wants to run best - and I'm pretty impressed with the available power. The engine is so pretty it's easy to forget that it's a real little dynamo!
#58
In no way intended for anything else than to provide as much as information as possible for "just in case". They are my experiences with converting these boxers, and if anyone can use it, then that is great, if not, still nothing lost. Your engine won't run any different for it
Durability depends on your fuel mixing ratio and whether you're light or heavy handed on the throttle.
I can guarantee from personal experience, that if you mix 10:1, keep full throttle limited to max 1,5 minutes (for me that brings a glider to 600 ft, which is where my eyes start to fail me), and make sure you do not exceed 9K in flight EVER, there are no durability issues, not even with the cheap slag-ASP
But what I like most is how frugal it is and how easy it starts.
#59
Mitch,
Sure runs.... and looks great. Your efforts are earning a fine return!
The durability, in most cases should improve with gasoline.
Gasoline itself has a bit of lubricity, methanol .... relies on the oil as it imparts little if any. Gasoline is far less corrosive than methanol based fuels, especially when nitromethane is involved. Of course, you can easily do without nitromethane when using spark ignition.
With proper care and handling, wear is really a small issue with either fuel. I have several methanol fueled engines that date back 40 years or more, Wear has not been an issue. Yes, that care and handling is a bit more specialized with methanol, but we do generally enjoy taking good care of the entire plane anyhow
Overheating however is a factor with gasoline, especially some conversion applications. Many converted glow engines do need their time spent at full loads limited.
As you know, starting either should be about the same. The broader rich/lean mixture tolerance makes methanol, especially CDI sparked methanol very tolerant and easy to start.
The high vaporization rate of gasoline usually makes for easy starts, especially in colder weather.
With CDI ignition, with similar engines you will burn about 1/2 as much gasoline for the same RPM with a given prop on methanol with zero nitromethane. Keep in mind, that zero nitro fuel costs considerably less than the typical 10%~15% fuel. Still not as cheap as gasoline
You will however have the potential for about 20% more power, plus the ability to maintain that power for extended periods.
With planes like the Rascal, a little extra power is seldom missed anyhow.
Great job!
#60
QUOTE: With CDI ignition, with similar engines you will burn about 1/2 as much gasoline for the same RPM with a given prop on methanol with zero nitromethane.
Jesse, this is something I hadn't mentioned so far but I have a teeny tiny gas tank in the Rascal (375ml or 12 oz) and it's just crazy how little fuel this thing uses. I'd estimate that I use 6 ounces for a vigorous 10 minute flight. Just amazing - especially compared to alcohol.
I also have a Saito FG60 three cylinder gas radial and that's where I first noticed how little fuel these gas 4-strokers use. It's 60cc and barely uses any gas at all.
#61
For normal relaxed flying at 5500 RPM with the occasional climbout however, the 8 oz lasts at least 40 minutes.
#62
My Clipped wing Cub with an OS 160 Gemini II CDI iirc had a 12 or 14 ounce tank and it was good for about 20 minutes with fuel to spare.
#63
Well since I posted last time I've flown and flown this little gem and it continues to run like a watch. HOWEVER - I did have an interesting anomaly happen today. It's actually the second time it's done this although I think it had the old 4-cycle walbro on it when it first happened.
So I had flown it vigorously one flight (maybe two) and it ran great as always. But when I went to start it the next time it started right up but would not accelerate. Full throttle would bog and begin to die. Long story short I used the choke to finally coax it back to full throttle and once it cleared it was right back to normal. Matter of fact I had re-adjusted the needles again and when cleared it was actually running even better. The transitions to full throttle are fantastic! I flew it a couple more times and could not believe how good this little thing runs.
So this is my theory: It was a pretty warm day, maybe 87 or so, and I'm thinking I had a vapor lock. Once I coaxed it into running up it cooled the inlet tract thereafter. I don't have a big carb insulator on my conversion: about 4 millimeters of nylon. I'm thinking I might make one out of phenolic and see what happens.
Bottom line: I'm still LOVING this thing!!
1967brutus (06-25-2022)
#64
So I had flown it vigorously one flight (maybe two) and it ran great as always. But when I went to start it the next time it started right up but would on accelerate. Full throttle would bog and begin to die. Long story short I used the choke to finally coax it back to full throttle and once it cleared it was right back to normal. Matter of fact I had re-adjusted the needles again and when cleared it was actually running even better. The transitions to full throttle are fantastic! I flew it a couple more times and could not believe how good this little thing runs.
FWIW: don't think too much of it, these things sometimes happen, and as long as things are stable in flight, what happens on the ground does not matter too much. In full scale aviation they have procedures for these kind of things, and back in the days of carburated cars, even on hot days, we also never drove off full throttle, because we all knew that was not the right thing to do. IMHO, this is no different.
And yes... Running gas REALLY changes the characteristics of an engine and the whole experience in general, doesn't it?
I have no idea how much fuel you have through it now, but my expectation is, that it will keep improving (while also needing minor needle tweaks) for about the first two gallons after conversion. Not shocking much, just a little every day, keeping that smile on your face fresh every day.
#65
I'm with you on this Brutus: I'm not worried a bit about this. It ran so great two more flights I can't get too upset!
I was just in the shop looking at it though and I notice my ignition box (which in under the engine in the cowl) mostly blocks a big air outlet at the bottom of the cowl. I cut a little air inlet in the cowl under the spinner just for the purpose of cooling things off in there but I fear I'm wasting it.
I'm going to see about raising the ignition box up a bit. It wouldn't take much to make a nice difference.
#66
Can you post a pic of the underside of the cowl installed? Indeed I think the ignition is obstructing outflow a bit, but a small "spoiler" in front of the exit opening, deflecting the propwash downward, has a huge positive effect on flow-through. I did that with my FW190 and it almost doubled the cooling efficiency.
But raising the ignition box by 1/2" should absolutely not hurt anything is my guess.
Personally, I am no fan of having the ignition box in front of the firewall, sooner or later it will get dirty and I dislike dirty electronics. But other than that, that is a tidy installation. Mine usually look a lot less "well planned"
#67
In the past I had often used a over sized refective heat shield. Made from thin aluminum pie plate material and installed between the carb and insulator block.Form as needed to block out carb from heat radiated from the engine. They can do an excellent job at keeping radiated heat away from the carb body.
BTW, The carb mounting screws should also have heat insulation measures at ALL contact points. Don't underestimate the heat transfer that takes place
#68
I’m gonna see how my cowl vent works before I do anything drastic
Yes, I put the rascal on the bench today so I could move the ignition box a good half inch above the cowl cooling air exit. Now my little cooling hole will actually Do something!
Here she was yesterday- flying to the moon.
#69
That exit hole is very ineffective to the extreme. A spoiler of 1/4"will increase airflow through the cowl hugely.
And looking at how much of the engine is under the cowl, I am actually surprised you're not allready having heat issues,,,
#73
#74
