UMS Gas Radial Engine Enthusiasts Rabbit Hole
#126
is it the 7-90? Did you try replacing the two spark plugs? Did you try movinf those two plugs to different cylinders to see if the problem follows the plugs to the new cylinders or still exists on the previous two cylinders?
If you have the 7-90 then I’m not sure how you are seeing spark coming out of the glass because the boot covers up the whole plug.
I have a new UMS 7 cylinder radial, ran good for half an hour then it became erratic, could not keep it running. Stalls on acceleration and found it misfiring. Discovered two cylinders with leaking spark arcing in the cable spark plug boots. You can hear and see the spark arcing along the glass body of the plug to ground... Has anybody had this problem? What can be done with it. I cleaned the plugs on the outside. Checked the gap. It is good.
#127
BC, CANADA
Timbers, it is a 50cc 7 cylinder. Yes, that is the first thing I did, no difference. I cleaned the plugs and reinstalled them. I see air bubbles in the fuel line originating at the pump. I will deal with the pump and let you know. It is still erratic, hard to adjust the carb...
#128
Ok
From my experience a cylinder that isn’t firing just lowers the top RPM of the engine. Erratic running can be the air you are talking about or maybe your pickup? Your pickup isn’t rubbing on the hub is it? I tightened the two screws for my pickup once and the plastic squished and the pickup was too close to the magnets and the engine ran really bad. Maybe check that too.
#129
BC, CANADA
Hello Timbers, You asked why I could see the spark, well only those arcing near the slott at the end. The slot is about 3/8 to 1/2 inches and those plugs arcing can seen. Others may arc hidden from the slot elswhere and cannot be seen, only snaping load enough to hear when turn over by hand, The engine speeds up when the plugs fire (cut in) for a second or so and engine slows down when the plugs cut out. I will check the pick up like you say. Find the airleak also... Thank you for the advice... Joe
#130
BC, CANADA
Got a couple of questions that I asked the supplier but no reply. Was asking what is the spark plug gap for the UMS 50cc- 7Cyl.??? Also, using a remote temp hand held sensor, what is the temperature expected on each cylinder head. I get a variation of 160 to 220 degree F.
#132
Doggy, less than full rpm acceleration and less than normal top end rpm, variation of sound are noticable indications of dropped or dead cylinders. Cylinders not running are usually just a small amount above ambient.
Lot of factors to consider. Fuel mixture and ignition consistency also may play a prominent role. Some of the ignition modules are finicky. Inconsistent at different voltages etc.
#133
Hi, Just got a new 7-50 for a Skyraider. Just fits cowl but is tight and a prop shaft extension would help. I may get away with a 1/4" spacer bush and using either 20x8 or 18x8 props to start with.
Horizon used to do an extension for the 7-35 glow but I dont think this would work. Any ideas?
Also I was told I did not need a pump with the 7-50 latest engines from UMS, Just keep fuel line short and tank same level. Some engines I ve seen are being sold with a pump. I have not come across a UMS carb before, looks like a glow engine carb so presume tuning is same principle (last time I had a glow engine was 25 years ago!).
The only thing I don.t like so far are the plug leads are about twice as long as needed for a small engine like this.
Thanks Ed
Thanks Ed
#134
BC, CANADA
Ed, I have the same engine, 50cc-7 cyl UMS with UMS carb. Poor instruction book, I did not know the plug wires have to go on with a hard snap to make them seat, otherwise they misfire, Also, I cannot find the spark plug gap in the UMS instructions either. Anyone know the spark gap and the proper cylinder temperature??
#135
I wanted to post this awhile ago but I managed to Maiden my Phoenix Waco 60cc with the UMS 7-90. Everything went well, I broke the engine in according to the directions by running a full gallon of gas through it at 4 minutes per run, letting it cool off in between.
It ran pretty well in the air. I have a problem getting it to get up to full RPM before the flight. Maybe I'm running it too rich, or maybe the bottom cylinders are just that flooded that it takes awhile to clean up, but it takes probably 3 or 4 minutes of warmup time on the ground before I can get it to spin to about 5400RPM and then I go for the flight. I'm running the APS Powerfuel RX pump at full speed when the engine is running.
Here is a video of the flight. Sorry its shaky and not very well done but I can't fly and video myself! I'm also linking a video of it running on the ground before flying.
#136
My Feedback: (62)
I tried to listen carefully. I did hear a cylinder come on as you throttled up. What drives me nuts is so many people blib the throttle or go from idle to full throttle and back a bunch of times. This tells you very little about how the engine runs. Throttle up slowly to full throttle and listen to hear a cylinder come on if it was not firing. If so , yes there is a problem. Did you tune the engine so it is not rich? Very definitely get a thermal temperature gun to find the cold cylinder and then check the plug to see if it is carboned up or not firing or both.
#137
Yes I have a laser gun that I have been playing with watching the cylinder temps. I had it clean up in the air really well one time and it was very powerful. In the Spring I will start experimenting with leaning the high speed needle a bit more to see if I can get it to clean up better on the ground.
#141
Timbers. Be patient, your engine will come alive with more run time and proper tuning. The fuel pump enables you to lean the needles slightly more. Leaning the low needle will have more resolve to proper low rpm running. Adjust the radio to slow the speed of the throttle servo to at least 1 second. Radial engines don't like to be slammed open. Give it time to come up to speed. Install temperature telemetry to monitor you temps. And last, do as Maxum say's.
Regards - J Tab
Regards - J Tab
#146
Biggest issue is everyone gooning over the thing as I do it lol. Fire away at that 100 Cc target. You'll be happy you did!
Aaron-
#149
My Feedback: (569)
UMS 260 Newbie......
Just happened upon this thread while 'googlin' on UMS260 radials.....very interesting/informative to say the least.
This 1/3 BUSA Stearman is one I bought many years ago and am only now getting around to 'refreshing' for flight....it's modeled after the full scale one in the second picture
It currently has an older 3W120 twin for power, which is more than adequate, but it really deserves a radial.....so I'm thinking UMS260
Would love to hear folks comments on this proposed setup, the motor and any 'words of wisdom' on installation and / or flying.
Thanks in advance
Thanks in advance
