FG-21 v FG-30
FG-21 v FG-30
Just got back into the hobby after a couple of decades out of it. My first building project for the winter is a dynaflite fly baby 1/4 scale 84”. Manual says target weight is 11 - 13 lbs. I want to go with a 4 cycle gas engine. Dynaflight recommended up to a 1.2 four stroke but I’m sure that was assuming a glow engine. They also suggested a us engines 25cc. Obviously an old kit.
On the gas side, an FG-21 is roughly equivalent displacement, but from what I’m reading it’s likely down on power from a nitro 4 cycle of the same displacement. Any thought on whether I should go up to the FG-30? I expect to fly this thing mostly on the wing, scale like speeds and gentleman’s aerobatics.
I’d thought about just going forward with the 30 now as it’s in stock and can be found on sale for the same price as the 21. I just don’t want it To be grossly overpowered or heavier than is reasonable.
Any help would be appreciated.
J
J
I think they both can do the job, but the FG21 might result in a pretty sedate flying style, and the FG30 might be on the wild side. Although I don't think it will be "grossly overpowered".
Weightwise, I don't think the 30 is that much heavier than the 21, and remember, you can fit a tank half the size of what is recommended for glow, so there will be a considerable weight saving there, at least "all fuelled up".
Had there been an FG25, then that would IMHO be the sweet spot.
IL
I went ahead and put an order in for the FG30. Might as well, its currently on sale for $180 off and is at the same price as the 21 and its actually in stock. Ill just fly really big loops and throttle way back on the downline.
J
J
1. The FG-30 is probably around 260g (over 9Oz) heavier than the FG-21.
2. For a "floater" the difference in power between the FA-125 and FG-21 are probably smaller than you think. Saito claims that the FA-100 and FG-17 produce the same power, it's an interesting statement/observation it appears that the ability to spin a larger prop (gasser) makes up most of the differences in power/thrust.
3. Assuming that the FA-125 and FG-21 have a comparable useable power, the FG-21 would have been sufficient. The heavier FG-30 may not improve much (if any) of the flying characteristics.
J
J
I hope you can make the FG-30 work for you. It is a beautiful engine; I wish it was about 8/10 the size dimensionally, I'd have kept it.
