Gas 4 strokes?
MI
Gas 4 strokes?
I'm new to gas engines and was wondering why none of the engine manufacturers mark their engines as 2 or 4 stroke?
Are they all 2 strokes?
can you get a 4 stroke gas engine in a 2c.i. size that's not a weed wacker version?
I know it's pretty obvious that they are two strokes, but RCV 4 strokes look like two strokes so I though it best to check...
Mitch.
Mitch.
ND
RE: Gas 4 strokes?
the only production 4 stroke out is made by honda, and is a weedeater conversion. remember gas engines don't have the power/weight of glow to start with, so a 4 stroke gas is really lagging in that department. I haven't heard of anyone running the honda 4 stroke conversion yet, it is heavy and also appears to have a wet sump oil system, meaning inverted could be very bad...
DC
RE: Gas 4 strokes?
And Stihl, Shindaiwa, and Ryobi, to name a few...The power/weight ratio is not very good yet, but they're making progress, and the Stihl and Shindaiwa use oil in the fuel just like a 2 stroke, no oil sump....
RE: Gas 4 strokes?
Zenoah has a 26.5 cc four stroke out there too,by far the Honda is the best,the flying weight is less than 5 pounds.Honda designed the oil systems to operate in 360 degrees of angle so inverted is not a problem.It has an oil resovoir but is not a wet sump.It turns a 18/8 to just over 6000.
RE: Gas 4 strokes?
Seidel, RCS and 3W have their radials.
The new 250cc 3W does 20hp on 5 cylinders. That is 4Hp for each 50cc cylinder.
Time to derive a single from this radial?
ND
RE: Gas 4 strokes?
I'd really like to see someone do the development work necessary to make these things successful in RC. That old stuff about 4 strokes not having the power potential to me is BS. Anyone seen a winston cup or an NHRA championship won by a 2 stroke lately?4 stroke power potential is there.Sure these little weedies don't match present day 2 strokes power wise, my guess why is because , most of 'em have an intake and exhaust tract about like a farm tractor engine, lousy combustion chamber shape, valves and ports half the size they could be, low speed industrial cam timing, compromise ignition timing etc. Put a box muffler off a weedeater, on your 3w and see how much power it makes. Personally, I'd love to see a mainstream manufacturer, such as Honda, get into this. The heaviness of the engine could be trimmed a lot I'll bet, and maybe it'd wake up OS,YS, Saito, name your favorite, to some facts about 4 cycles. No 1. why on earth does a 4 cycle engine need glow fuel and a glow plug? It doesn't. Put the oil in the crankcase where it belongs, and quit diluting the fuel mixture with it. Diluted fuel mixtures should be the province of the 2 stroke, not 4 strokes. Put on an ignition system, a good Hall effect system, with controllable timing, weighs a few ounces, offset by the power increase of being able to run straight gasoline, and getting rid of the heavy magneto flywheel. put on a REAL carburetor, with mid range metering etc.Change cam timing to something appropriate to the rpm range used in a model airplane, with valve and intake/exhaust port sizes to match. A 2 stroke operates with a compressed fuel charge that's half old exhaust, and oil in the fresh charge. No 4 stroke suffers from these obvious defects in its operation, or shouldn't anyway.
IN
RE: Gas 4 strokes?
Four stroke gassers could be designed to compete with the 2-strokes on power. They would be more costly than a 2-stroke and also have more of a "shake" from the power pulse, and it would be taller. Take a look at a YS 4-stroke, then think what would be required to make it run on gasoline. Add needle bearings to the connecting rod and rocker arms, plus a roller cam, a diaphragm carb, add an ignition, eliminate the standard regulator and tank pressure system, and run a gas/oil mixture like a 2- stroke. Considering a YS 1.40 costs about $500, you could probably sell it for about $750. And that would be for a baby 4-stroke around 40cc.
ND
RE: Gas 4 strokes?
ORIGINAL: Diablo-RCU
IN
RE: Gas 4 strokes?
Sat Pete:
The reason you don't see 'em, is because there is no market for the kind of engines you propose. What works for full scale, does not scale down very well for a model. No manufacturer wants to make a huge investment in something like that with an unlikely chance to make some money.
DC
RE: Gas 4 strokes?
A Zenoah 4 stroke 26.5 ?????
Weight..The extra pieces and parts weigh more than a crank and piston....
I converted a new Shindaiwa, the latest technology, COPIED from YS...Not enough power for the weight..Oil in the fuel is not a big deal....
Honda had some 4 cycle racing motorcylces, 125 cc 4 cylinder, sosmewhere around 22,000 rpm, a power band about 500 rpm wide..They had to use 8 speed transmissions to be able to use the power..
DC
RE: Gas 4 strokes?
Probably, but the 4 stroke weedies that use oil in the fuel have ball and roller bearings throughout, and the fuel passes through the crankcase before going to the carb...Takes WAY less oil than a normal 2 stroke with bushings on both ends of the rod, and since the cam is some kind of plastic they can get away with it....
IN
RE: Gas 4 strokes?
Most of the 2-stroke emissions are from unburned gasoline, not unburned oil. The intake mixture coming through the transfer ports can exit out the exhaust port before the piston closes off the exhaust.
ND
RE: Gas 4 strokes?
Sat Pete:
Sat Pete:
RE: Gas 4 strokes?
Pete - build one -
It ain't that easy to scale down and get the results you say are available.
Again -look at the newest little Honda 4 strokers -for th public use - and that's what we are -- it don't get no better.
ND
RE: Gas 4 strokes?
Thats only because the little Honda is a purpose built engine, designed to run a weedeater, not a propeller. I don't see too many lawn boy engines in 40% extras either. Thats like comparing a formula one engine to a briggs and stratton.
WY
RE: Gas 4 strokes?
Just to muddy the water a bit. Two models have flown across the Atlantic, one with a Enya 155, the other with an OS 61. Both 4c both running gas/colman fuel.
I showed a gas Enya at Toledo a few years ago, lots of intrest until the price came up. Then the coment was "why bother I can run a 90 2c for a $100"
WI
RE: Gas 4 strokes?
Going to 4 cycle gives you a quieter engine and one that muffles easily, the draw back is weight and performance but a YS style 100CC twin made for gasoline would interesting.
Want power and low weight? The Wankel is really good for power in a small package and low weight, the problem is cost and a fairly hot exhaust that must be contended with, muffling challenge is between 2 stroke and 4 stroke as far as noise is concerned.
Want the power we have now in the 100 CC class engines but with smoother running and much better transition and fuel economy plus much lower engine shaking forces? A good fuel injected 2 stroke is hard to beat. The problem is cost and some weight gain.
Europe has some fuel injected 2 stroke scooter engines that are in production now and there are Personal Water Craft 2 stroke engines that have been made for several years with a direct fuel injection system made here in the US.
There are changes being made to small engines now because of the EPA, they are setting new standards for emissions, this will ultimatly effect the R/C industry in several ways in the not too distant future.
Some interesting configurations are being looked at by some R/C engine manufacturers that may well change the 100+ CC engines we use now, this may be sped up by the EPA.
Bill K
Bill K
RE: Gas 4 strokes?
the Honda is not a weed eater engine --it is a scooter engine.
Any of you guys build engines?
Hondas? Chevs? Studebakers? Triumph? Maxwell?
As you make the four stroke small - things have to change.
As simple a thing as a rod cap and bearing get to be pretty tricky.
The fob on my car keys is a conrod from a '40's O&R twin (two stroke ) and it has a rod end cap .
I just threw that part in for other geezers --
ND
RE: Gas 4 strokes?
Do I build engines? No. I'm a toolmaker, and I build injection molds and die tooling everyday that'd make an engine seem like falling off a log by comparison. Don't believe that? Have you ever created CAD geometry and toolpaths over it using a CAM system to produce a cylinder head on a 5 axis CNC machining center? I have. If you take a good look at the average model engine, the machining and EDM techniques necessary to produce the casting dies are about 100 times more complicated than the actual machining of anything in the engine proper. I make my living doing CAD design and CAM assisted CNC machining. I have one job, I don't need another. To tell me that something can't be built, or that it won't scale down is pretty funny really. This "can't do" attitude is why this country has lost most of its industrial base. If you talk to the average car guy, their idea of " building" an engine is assembling it. I got news for you, the guys who built it are all employed by the original manufacturer.
MI
RE: Gas 4 strokes?
Thanks for the interesting reading guys.
I just checked out the RCV website, and they have a 50cc prototype engine that they are developing,
as well as there are notes about building engines for UAV's. (hopefully 150-200cc!)
hopefully through some of this work, they'll market the 50cc + engine for model use.
I think that if they do market this engine, it would be a hit, even if it was they're
CD (crank Drive) range of engines. I just read that they're new .91 size CD 4stroke
is about the same external dimensions as a 50 4stroke, aswering som of you guy's concerns about size and weight...
For me I'll never go back to 2 strokes, I just love the sound and the torque of the 4 strokes.
A 150 saito screaming in a dive, combined with the whistle from the cowl.... you just can't beat it.
Maybe I could sign up for their 50cc engine test.... and just not return it...
Mitch.
Mitch.
DC
RE: Gas 4 strokes?
The sleeve valve technology that the companies are calling 4 strokes goes way back to the '20s...It's a variation of the old Knight engine that had rotating cylinder liners that acted like valves..There's not much new under the sun...A 4 stroke to me is an engine with at least one intake and one exhaust valve operated by one or more camshafts..
SEMANTICS....
SEMANTICS....
