Roto 25
#251
AB, CANADA
RE: Roto 25
I cut a hole large enough for the cap to 'just' go through, and fashioned a snug fitting plug that accomodated a rubber grommet the right size for the wire. Split the grommet, put around the wire, then stuff the plug into the hole.
#252
CA
RE: Roto 25
Raston, looking at your pictures I see that now. Good job as I had not noticed the "plug" before.
This is how I did it on my Christen Eagle so I guess good minds think alike
However I have seen pictures of some peoples planes and no plug is visible. I have to assume they desoldered the cap or something.
On my new GP giant stik I was lucky that it had a hatch plate on the bottom so all I had to do was cut a notch in the end of the plate to run the spark plug wire.
Had it not had this plate there was not a whole lot of space to drill a giant hole in the fire wall for the cap to fit through!
BTW, my Roto 25 is on this stik for now until I finish the spitfire. The 25 will come off the stik and be replaced by a 35.
The 25 fly’s this stik really well but it could really use a 35 for all out performance.
Bob
Pictures of my stik below
Bob
#253
RE: Roto 25
Richard. L,
Thanks, your suggestion helped me much.
finless,
I installed the ignition module on the firewall with adhisive
tape, ignition battery is after the firewall in the fuselage.
I wanted to place the ignition module as far as possible
from the receiver and the C.G was just fine, and no big
hole was needed on the firewall.
finless,
#255
RE: Roto 25
ORIGINAL: Richard L.
Tsutomu, so engine heat has no negative effects on the ignition module?
No bad effects so far, for several flights though.
I made a relatively big hole under the cowl as an
air outlet. That may be working well.
Tsutomu Mabuchi
#256
FL
RE: Roto 25
Finless. your installation looks terrific. I think the Roto 25 is just what I need for my GP Ryan STM. Is that a bisson muffler you have installed? I need the narrowest engine/muffler package I can get.
Thanks, Yak
Thanks, Yak
#257
CA
RE: Roto 25
Yak, it is SuperSonic I think. I got the engine with the muffler and the seller on RCU told me he got it from RCShowcase as an option so I assume that is what it is. However he told me it was a Slimline muffler and RCshowcase does not offer slimline for the ROTO 25. So which it is I am not sure. To me it looks like a Slimline as I have Slimline mufflers on other nitro engines. Still he said he got it from RCShowcase......
RCShowcase does not show a picture but the URL is here for the muffler they offer:
[link=http://www.rcshowcase.com/html/accessories/mufflers.html]http://www.rcshowcase.com/html/accessories/mufflers.html[/link]
Scroll to the bottom for ROTO 25 and it lists a SuperSonic.
When I check the Slimline web site I do not find the ROTO 25 listed but if it is a slimline then it must be the same bolt pattern as another engine they list.......
Slimline is here:
[link=http://www.slimlineproducts.com/]http://www.slimlineproducts.com/[/link]
Sorry I could not answer you properly but I am just unsure.
Bob
Slimline is here:
Bob
ORIGINAL: Yak18
Thanks, Yak
Thanks, Yak
#261
CA
RE: Roto 25
I have been watching this thread for a while and taken bits of advice from many. i mounted my Roto 25 in a 1/4 scalt balsa USAFokker D8 picured here. Performance is spectacular, engine is smooth and power plenty for this 13Lb model. i used a steering arm for both throttle and choke, mounting the servos for both on the firewall. no interference issuse. i am spinning an 18x6 simitar prop which looks great and runs well. This is a fantastic engine. i am buying another one for my next scale project. i will then own two.. maybe a twin is in my future!!!!
#264
RE: Roto 25
Dear Tsutomu,
I would like to install ROTO 25 or ROTO 35 on my giant scale Hangar 9 Cessna 182.
Please advise where possible to buy nylon mount?
Best regards,
Boris Kharchenko
(Russia Ekaterinburg city)
Best regards,
Boris Kharchenko
#265
CA
RE: Roto 25
Roto 25 will pull the big H9 cessna very well. Ive seen them fly on everything for a G23 to a G45!!! It has at least as mouch power as a G26 and is a smoother running motor.
#266
I am building the seagull van's rv8 I still haven't picked an engine for it. Should I go with dle 20ra or roto 25? It will be my first gasser. (weight is not a issue since the model requires nose weight even with a dle 30)
