Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 I need a good gas fuel pump setup!! >
Old 04-25-2005, 11:38 AM
Default RE: I need a good gas fuel pump setup!!
Just use the bike tire pump and save yourself a lot of money and work. It does not get any easier than that.
smallplanes
Old 04-25-2005, 01:08 PM
ORIGINAL: desertpig
1 > 1 or 2 Gal ventless gas can (home depot / ace, etc..) $4
2 > Sig "Gass Passer" sealed gear type fuel pump $30
3> Radio shack sealed 5A DPDT switch $5
4> Batteries Plus 5AH 12V sealed battery $25
5> Dubro Tank adaptor - $7
6> Tygon / Aerotrend fuel line $3
7> Sullivan "crap trap" filter $6
8> home built tote box - $0
Total investment - $77
BTW - all modern fuel injection systems, aircraft fuel delivery systems and racing fuel cells have sealed motors that are immersion type (i.e. are running inside the tank or cell immersed in fuel). You don't have to worry about sparks from the motor or switch setting off any fumes.
DP
Actually, my investment was a little higher than that (these are approximate):
1) Anderson Pump: $37.99
2) Radio Shack sealed 5A DPDT switch: $5.49
3) Radio Shack Momentary Switch: $2.69
4) 4' x 8' 3/8" Plywood sheet: $12.99
5) Electric Brad Nailer: $59.00
6) Electric Random Orbit Sander: $69.00
7) Deck screws that I didn't use: $5.00
Total: $194.16
I already had:
1) Dubro fuel tank and hand pump: $24.99
2) Tygon fuel tubing: $5.00
3) 12v Gell-cell Battery(pulled it from a broken Sears rechargeable car air pump) : $17.99
This is still cheaper than buying one of those commercial hobby fuelers and I get to reuse the sander, nailer, screws, and most of the plywood.
Old 04-25-2005, 01:13 PM
My Feedback: (61)
Jim - that's pretty funny! I have a house full of tools I bought too from all the projects that "costed less" than having someone else do it!
DP
Old 05-14-2005, 05:30 PM
My Feedback: (38)
JohnVH's Avatar
Check this baby out, Stainless backplate A little something something I made this morning
ID:	271445   Click image for larger version
ID:	271446   Click image for larger version
Old 05-14-2005, 09:48 PM
BARCC,
I use the 1 gallon setup from Jersey Modeler with the yellow plastic cap and it has worked just fine for me. It was worth the $44 to me to get a reliable setup.
Travis
Old 05-15-2005, 07:27 PM
  #31
To All,
Be careful what sealed means. Is it intrinsically safe from vapors, or sealed from dirt. From what I have seen, most electric gas setups are not right for gasoline, but they get by.
Manual works very well for me.
ML
Old 04-03-2009, 08:00 AM
  #32
My Feedback: (21)
mrbigg's Avatar
I'm thinking of going with the Sig "Gas Passer" sealed gear type fuel pump and Radio shack sealed 5A DPDT switch. How are you guys wiring it up so that you can fill and drain the gas?
Old 04-03-2009, 11:01 AM
  #33
Mr. Mugen's Avatar
http://www.chiefaircraft.com/rcmsec/...uip/Abell.html
I bought the 25 elec. I couldn't be happier. I use a 2s 2100mah lipo and went all last summer on one charge. When I recharged it there were only 1500mah's gone....from may-oct! Like I said....couldn't be happier. It also takes the fuel out of your plane in seconds as well.
Kevin
P.S. Hangar 9 makes a hand pump for 15 bucks that works good too.
Old 04-03-2009, 11:43 AM
  #34
I had that six shooter- it is AWFUL!! The glow version works great, but I think the stiffer gas proof tubing makes the gas version hard to crank.
I hear ya pal! I am just getting into gassers and picked up a Six Shooter since I had used the glow version and really liked it. Before I had a half an ounce in the tank it came apart! It was extremely hard to crank and then the tube came loose from the fitting and leaked all over. I was so mad I tossed it in the trash and went out and picked up a geared type (Hobbico I think) pump which has been working good.
I thought of an electric pump but every glow electric pump I've ever had leaked at some point and the fuel ends up in the motor. Not going to take a chance with that happening with gas! [X(]
Mike
Old 04-03-2009, 09:23 PM
  #35
The only thing I can say about this thread is WOW!!! Man I have a one gallon tank from jersey modeler, the best thing I ever bought, mine is a manual pump, not electric, I dont mine turning the handle, im not lazy. Oh yea, Dean is the bomb, one of the nicest guys ive talked to.
Old 04-04-2009, 06:57 PM
  #36
My Feedback: (21)
mrbigg's Avatar
I'm not lazy either, but my planes have 40oz fuel tanks. It gets cranking the pump. My electric pump will also be filling my lawn mower, trimmer, snowblower, leafblower, and dirtbike. I plan on getting a good return on my investment. I wouldn't buy anything from Jersey. Too overpriced.
Old 04-06-2009, 12:28 AM
  #37
2robinhood's Avatar
I made my own set-up.
Two one gallon cans, one for gas, the other for smoke.
Using two sullivan 12v pumps made for smoke fluid.
Haven't had any issue with the pump running the gas
12V sealed battery inside toolbox.
ID:	1173810   Click image for larger version
ID:	1173811   Click image for larger version
Old 04-07-2009, 06:06 PM
  #38
Wingman26's Avatar
The trick is to find a gas container that actually has a cap on it! So far all I can find is ones with built in spouts that don't really seal the can, they are OK for filling the lawn mower, but not very suitable for adding the hardware to use it for fueling.
Old 08-23-2014, 08:27 AM
  #39
Default Gas, Kerosene, Smoke & Nitro fueling systems
www.rcfuelingsystems.com
Great product!!!!! Affordable pricing!!!!!
Old 08-23-2014, 10:12 AM
  #40
av8tor1977's Avatar
Sometimes you can score a real honest to god old fashioned metal can with a normal screw on cap by buying a gallon can of paint thinner or Coleman Camp Fuel at the hardware store. Also, Hobby King sells a gasoline rated electric fuel pump for under 10 bucks. I have one but haven't tried it yet. I heard from another member here that they work fine.
AV8TOR
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
