CRRC GF45i
#1603
RE: CRRC GF45i
ORIGINAL: jetrichie
I have a 26cc engine and it has been perfect, my new 45cc engine is glitching like mad with 2.4 or pcm, would wrapping the ignition box up in silver tape help
Check that the spark plug cap is on properly, it was tight but it was not pushed all the way home.
They are really hard to get on properly.
Ever since then this engine is sweet as, very happy with it.
Cheers
Paul
#1604
RE: CRRC GF45i
ORIGINAL: jedijody
Put a small hose clamp on the spark plug cap right where the hex of the plug is, tighten it until the cap cannot rotate on the plug easily. About 95% of RFI is caused by a loose fitting spark plug cap.
#1606
LA
RE: CRRC GF45i
HI guys need some help on a CRRC 50 pro. I have the silver ignition box installed on a Great Planes Giant Stick. When I crank and run the engine I have a hit through the ignition on my controls. I have disconnected the metal throttle linkage and still have the same problem. Can anybody help me? Thanks.
#1612
RE: CRRC GF45i
PCM Reciever cleared up my problem!!!
microproc in (The PCM briefly goes into failsave so the glitch will be difficult to detect).
Best Regards
#1613
RE: CRRC GF45i
I saw a few problems with glitching, I have a GF45i and it didn't glitch once in the year that I use it, even with the stock CDI.
And I never used PCM in my life, so what's happening?
It's always difficult to solve problems 4000 miles away from it but I'll give it a try.
There's a lot to say about computers ( that what is inside a PCm receiver) so I 'll keep quite about it.
A good setup requires that you start with the most sensible configuration that is a PPM receiver that sees and hears
everything. When you experience glitches it means something(s) is(are) not quite as it should be.
How to generally solve?
The following goes for all engines, cheap and expensive, gas and electric
1) try to establish source of glitches( ignition , speedcontroller, metal to metal). OK you are sure, it's the ignition.
2)keep it and it's battery as far as possible from the receiver and / or electronics that are connected to te receiver.
3)make unit, battery and switch as compact a bundle as possible and in case of electric motors keep the wires of power bundles as close to eachother...you guessed it... as possible or twist.
4)make sure that the screen of the plugcable doesn't touch any other metal than there were it should touch
more explicitly the base of the spark plug. Wrap it in plastic tape all along from cap to cdi and see to it that ik doesn't
wiggle about too much.
Some other remarks are, watch out for killer switches, ferrite coil in series with cdi power won't hurt but keep it as close to
the unit as.... possible.
If you can cure this business with a PPM receiver, your system is ready for PCM.
If you got glitches with PPM you allso have them with PCM only the receiver will experience short datacuts that result in
poor response time, short failsave situations and while you are walking with one foot over the cliff, a randomly small
deterioration of the situation can turn your receiver in prolonged failsafe what will kill your modell.
Best regards
Best regards
#1614
RE: CRRC GF45i
ORIGINAL: cuwaert
Don't believe it, it MASKS the problem. Primary electronics must operate flawlessly before you put a
Best Regards
Best Regards
I was going to suggest the same thing. PCM is great for filtering out the odd problem but it shouldn't be used to hide an obvious issue. Your receiver could be fraction away from locking out at all times and you'll never know.....until it's too late and locks/holds you out (which could be for quite some time if the problem is that bad).
#1615
My Feedback: (23)
RE: CRRC GF45i
That's how it started. I have a plane with a PCM receiver. I need to put a PPM reciever in it to make sure I don't have any glitch's. If I do I must reconfigure the whole plane move the battery's all around and make it Glitch free with my PPM receiver. Than after I have pulled all the rest of what little hair I have left out. I can put the PCM receiver back in and go fly knowing! I've punished myself enough for posting a question on RC Universe. Let the opinions Fly!!!
#1616
RE: CRRC GF45i
I dont know anyone that flys gassers with PPM, its all PCM or you have trouble.
Don't believe PCM masks anything at all, it just works. (I dont use failsafe either)
All my gassers and everyone I know use PCM RX's with no problem at all.
Why waste time and sanity on PPM.
Too many people get too technical.
Cheers
Paul
Cheers
Paul
#1617
RE: CRRC GF45i
It's not getting technical, it's getting it right. A properly set up gasser works fine with PPM, I do it all the time. Just like in the old days when we were flying gassers on unshielded magneto ignitions with AM radios. If you can't set up a gasser to work safe and trouble free on PPM you are not going to be safe with PCM, 2.4, or anything else.
#1618
RE: CRRC GF45i
ORIGINAL: jedijody
You are indicating that PCM etc is wrong from day 1.
We use PCM all the time without issues, and thats my point you can use PCM without any issues and without it masking problems, we do it every weekend.
Sure if not setup properly you will have issues with anything PPM, PCM or 2.4.
To say it must work properly with PPM first or it wont with anything else/masks problems is just rubbish, if setup properly there is nothing to mask.
The RF noise from the plug cap not being on properly still shows up with PCM as it does with PPM.
Hope this helps clear up some confusion.
Cheers
Paul
#1619
RE: CRRC GF45i
ORIGINAL: pc55bomber
A very misleading and incorrect statement.
Cheers
Paul
ORIGINAL: jedijody
Cheers
Paul
To tell someone that is having RFI problems on PPM to forget it and use a PCM instead doesn't help them at all and could be dangerous to at least his model airplane, helping them find the problem and work through the solution with proper and proven troubleshooting and set up technique is the right thing to do.
#1620
My Feedback: (23)
RE: CRRC GF45i
Thanks Paul
We were in your Country in 2002 Very nice experience.
That's my point. If I did not put the PPM in the plane I would not have noticed a problem. I run PPM with three other gassers I have. 1) Cinmaster Revoultion 50,2) Brison 3.2, 3) Zenoah G-38 magneto. I usually shield the ignition away from everything else and it works well. I never had issues like I have had with this engine. I put the PCM in it under recommendation, and now I can fly it. I've had no problems in the air or on the ground.
#1621
RE: CRRC GF45i
Hi Jody
No I am not confused, what you wrote, what you meant and how people interpret it is confusing.
I agree if you have a problem you must fix that problem, regardless if it is PCM or PPM, setting it up right in the first place is the key.
The inference that comes across is that PCM only masks problems, when that is clearly not the case.
Yes I have experienced problems with PPM and going to PCM has eliminated that problem without any further issues.
So it can and does happen in practice but it is not the cure for all problems.
Cheers
Paul
Cheers
Paul
#1622
RE: CRRC GF45i
Cheers
Paul
Cheers
Paul
PCM does mask poor signals, it's the nature of the beast. PCM rejects bad packets and, if it gets enough of them will go to hold or failsafe. Without prior testing you have ZERO idea if you have any glitching or how much of your signal is being rejected (because PCM is masking it).
Yes, move to PCM once you've ascertained you have no interference. Use PPM to determine any interference and deal with that first.
#1623
RE: CRRC GF45i
Cheers
Paul
ORIGINAL: jedijody
Cheers
Paul
You use PPM to test for glitches, then minimise them as much as possible, only then can you take on the added safety PCM gives. You rely on PCM to protect you from occaisional glitches, not as the primary means of filtering out persistent interference. To jump straight to PCM means you have no indications of any glitches.
Testing with PPM will show any glitches, giving you the opportunity to resolve them before the maiden flight. PCM doesn't do that.
PCM does mask glitches by rejecting bad packets of data. How many glitches is your PCM receiver rejecting? Unless it tells you (and some can) you have zero idea. You could be so close to a failsafe/lockout you won't know until it happens.....a bit too late to claim PCM saved you.
By all means use PCM BUT don't be lulled into thinking it's going to magically protect you if you have installation related interference.
#1624
RE: CRRC GF45i
Hi Jody
Cheers
Paul
Hi Jody
Cheers
Paul
We definitely agree on fixing problems prior to flight, hence why a good test regime is required prior to a maiden flight.
I do disagree with your belief PCM doesn't mask problems. A quick google on receivers, PCM signals, and review of manufacturers sites will change your mind.
Every time a PCM receiver gets a packet of data it decides whether it's correct or not. If incorrect it decides what to do with it, which is generally to ignore it and read the next packet. This happens approx 50+ times per second (depending on manufacturer etc). If a string of suspect packets are received, then hold or failsafe is applied.
If the odd packet is rejected you won't notice it, hence those packets are masked from you. If enough packets are being rejected the receiver will go to hold/failsafe, only then will you know you have a problem.
PPM isn't superior to PCM but at least you can see the problem as it occurs (hopefully on the ground). Not testing using PPM means you have no idea if you have an underlying problem.
#1625
LA
RE: CRRC GF45i
Thanks for all of the tips. I flew my plane for the first time today. After 3 dead stick landings, I finally got it operating correctly. I did find out that the spark plug cap on the crrc50 pro must cover the hex head on the spark plug. I did not have the silver cap all the way over the hex head; didn't realize it was that important. That was the source of a lot of my problems. The motor runs flawlessly now.
