Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
Reload this Page >
Pls share pic of your servo/throttle linkage on G26 or similar
Old 12-10-2005, 10:30 AM
Magna
Default Pls share pic of your servo/throttle linkage on G26 or similar
Hi all
Just got my first gasser Zenoah G26 to go into my GP PT19. The throttle link up is not the usual Glow type but a metal ear with lots of hole for a particular angle of connection/linkage.
I will mount it inverted so I like to see some ideas or picture as reference for me to work on the mounting and installation.
Thanks in advance for the helps.
Old 12-10-2005, 10:47 AM
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
Default RE: Pls share pic of your servo/throttle linkage on G26 or similar
This is not your plane but the linkage is the same.
This is a Central Hobbies 2-56 carbon fiber rod with titanium ends. JB Weld is used to glue the ends on. Use 2-56 ball ends on both sides for a slop free, bind free throttle linkage. I like the CF rod setup because it's stiff and strong and you can cut it to a precise custom length (no z bends). The throttle servo is a Hitech 5245 mini digital using the stock aluminum arm that comes with the servo.
Old 12-10-2005, 04:36 PM
Halogen
I spent a lot of time trying to see the best setup to connect the throttle linkage to my evolution 26GT. All I did was I placed a peace of flat alluminium bolted on the carb throttle arm so that I extended the length without complicating things and using ball linkages and good quality plastic snakes .
I found it very difficult to attach the small bolts to the throttle arm but things get easy when you dismantle the carb and remove the throttle arm out of the carb
Old 12-11-2005, 07:50 PM
RTK
RTK's Avatar
Contact RCIGN1 here on RCU or his web site rcignitions.com.. buy a carb rotation block from him and toss all those bell-cranks and other related garbage. Better yet, have him do a converstion to electronic ignition and save a pound of weight off of the engine.
Old 12-11-2005, 09:36 PM
karolh
RTK,
That's a nice looking home for your G26, what model is it.
Karol
Old 12-11-2005, 09:49 PM
Magna
RTK
Unfortunately I'm half way the other side of mother earth...I will check out his site for more info.
Old 12-11-2005, 10:00 PM
RTK
RTK's Avatar
Karolh--Dave patrick edge--13lbs dry
Magna--he ships anywhere, I believe
Old 12-12-2005, 06:55 PM
Magna
RTK
That big servo arm on your carb, I take it that is your choke? How you access it for starting or you just cut a hole in your cowl and poke your finger to flip it? So with that conversion, your throttle linkage on the same side as choke lever?
And Thanks to all others for the great input and sharing thus far.
Old 12-12-2005, 07:19 PM
RTK
RTK's Avatar
ORIGINAL: Magna
RTK
You could put the choke arm on either side. Actually that is a nose wheel steering arm drilled out to fit. I just put my finger thru the front of the cowl to turn the choke off and on, no cutting holes. I usually use a servo, but wanted the plane to be as light as possible.
Ralph
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
