Webra Bully Questions? Pls Help
Old 12-12-2002, 01:58 AM
WorldModelNut
Default Webra Bully Questions? Pls Help
My first post.
I have a Webra Bully on glow. The engine appears to have low time, but I do not know the history. How do I tell if the carb is indeed the correct glow version. It is a Walbro. Also I have no instructions. What oil content should I use. I currently run my G-23 Glow on 5% oil and 15% nitro. Would this work for the Bully?
I have not tried to fire it yet. Any tips from some who have experience with a Bully glow.
Thx
Don
Old 12-12-2002, 04:15 AM
Antique
Antique's Avatar
Same fuel will work fine...The carb is correct if you can richen it enough at high rpm to make it slow down....Less nitro will likely work just as well, and cheaper....
Old 12-15-2002, 08:32 AM
rctimm99
My Feedback: (34)
Do you have the instructions? It should call out a lower oil content (12%) and no more than 15% nitro. This is a low compression engine, however, you have bearings at the top and bottom so too much oil is a bad thing.
I have the instrcutions if you want a copy
Old 12-15-2002, 07:46 PM
raineman
Default Wanna sell it?
I just got a plane with a Webra Bully 35cc on glow. I am so impressed with this engine that I want another! This is one of the most powerful glow engines I have ever used. I am running a 20 X 8 APC prop and I am getting over 8000 RPM using Wildcat 5% nitro, 10% oil. The plane has unlimited vertical. I am really blown away by this beast!
Old 12-15-2002, 07:48 PM
raineman
Default RCTIMM99
I have a Webra Bully 35CC w/o Instructions also. May I get a copy?
Old 12-15-2002, 10:03 PM
gachezem
My Feedback: (20)
Default 35cc bully
the webra bully runs on FAI fuel, (alky+oil) nitrated fuels will cause corrosion in the carb, unless you flush them out after running, best bet, put ignition on it and run gas + oil, I have one I run on gas, run's 8650 rpm w/18x8 I have not tried larger props yet, but it seem to be a very good engine for it's vintage.
Old 12-16-2002, 01:29 AM
raineman
Default gachezem, Thanks for the good advice
That is a new one on me. But, I have read that the engine is not as powerful when running gas. It will lose about 10% of power running gas.
Gchezem, How do you suggest that the carb be flushed and with what? It would be a good thing to know. Thanks for your advice. I would like to keep the new carb on this thing as clean as possible. I look forward to your reply.
Old 12-16-2002, 01:35 AM
raineman
Default Gachezem, one more thing...
Where can I get FAI fuel and which oil should I use? In other words, I have never mixed my own fuel. ANy advice would be great!
Old 12-16-2002, 02:00 AM
WorldModelNut
Thanks to all who posted on the Webra Bully. I would very much like to get a copy of the directions and specs. How could we obtain this from the person who said they would share?
Also, on the oil content. On my G-23 glow I mix my own fuel with 5% oil and 15% nitro. I use the Klotz synthetic oil. This brings my fuel cost down to $8/gall.
So, what does it say in the directions about the oil content for the glow Bully?
Thx
Don
Old 12-16-2002, 02:47 AM
Antique
Antique's Avatar
Very good engine for ANY vintage...What's better ???
Old 01-06-2003, 04:00 AM
raineman
Where did your low and high needle settings end up?
Old 01-06-2003, 04:35 PM
gachezem
My Feedback: (20)
Default needle setting's
I run my bully on gas and oil so needle setting's would be quite lean for alky/oil (glow) aprox 1/2, has any body found a suply for part's??.
Gary
Old 01-06-2003, 06:43 PM
captinjohn
Default Bully engines
How smooth running are the Bully engines. Are they smoother on gas or glow? Or same? Thanks Captinjohn
Old 01-06-2003, 07:30 PM
raineman
They run on gas, nitro and metho. You can change between a glow plug or a gas spark plug. The carb can be Walbro for gas or glow. They are very powerful. I am swinging a 20 X 8 @ 8300 rpm running 5% Nitro S-Tiger by Wildcat. Expect 10% less power on gas. Not sure what it is on Metho. Anyone? I understand they have bearings in the front and the back. I am no mechanic, but I understand it helps.
Very smooth motor.
Old 01-06-2003, 08:12 PM
gachezem
My Feedback: (20)
Default Bully on ags/alky
As far as the difference between gas and Glo or alky, I think you would have a hard time telling the diff, Gas would have a little bit sharper Exhaust note, Glo fuel next, alky/oil the softest, Easyiest starter on gas/oil (also best slow idle) If you don't want to go ignition, there is really no reason to run nitro, except in maybe extreme cold condition's where an ignitor would be of help in idleing/starting, as far as power minene pull a BSA Phaeton/Bipe staight up forever (hvy14lb) take off's are lift off Go KE and climb out, rather impressive (I think) and seem's to run forever on
16 oz fuel.
Gary
Old 01-06-2003, 08:43 PM
captinjohn
Thanks Gary. Next time I see a Bully at a swap meet, I may come home with one. I have mixed my own fuel and used Klotz for the oil mix. How is the weather near you in Oregon? Snow and cold here in Mich. Take Care John 3:44 pm
Old 01-06-2003, 10:05 PM
WorldModelNut
John;
Ran my new Bully the other day on 5% oil and 15% nitro. It loved it and purred like a kitten. Very smooth engine. Very good throttle response with a Delorto carb.
Thx
Don
Old 01-07-2003, 01:13 AM
captinjohn
Hellow W.M.Nut: Sounds like you got a nice engine there. If you can..... post a picture of it. I have seen the Delorto carbs on some other engine....but cannot remember what they look like. Is the carb made in Italy? Thanks John
Old 04-09-2003, 01:59 AM
locomotive
My Feedback: (7)
What size tank are you guys running with glow?
Old 04-09-2003, 02:01 AM
locomotive
My Feedback: (7)
Bisson says they don't make mufflers for the Bully. Anybody know if any current engines have the same port shape?
Old 04-09-2003, 03:43 AM
JohnnyJ
Default Webra Bully
Hi,
3W 35 and 40 mufflers will fit the webra bully.
Good flying!
John
Old 04-09-2003, 01:17 PM
popierre
I have two webra Bully runnig on glow, I was using 7% Graupner synthetic oil and 0% nitro without problem, no rust. I am back in the Sates now and you can run on FAI fuel or Morgan7 fuel for Bully/Tartan.
You don't want more than 5% nitro and 7 to 8% oil, more nitro will wear out the engine fast. I am looking to make my own blend using powermaster or Wildcat and cutting it half with pure methanol.
hope this is of some help.
Old 04-09-2003, 03:03 PM
locomotive
My Feedback: (7)
What size tank are you guys running?
Old 04-09-2003, 03:27 PM
locomotive
My Feedback: (7)
I can't find a BCM muffler for a Bully, a 3w-35, or a 3w-40. I am trying to buy a Bully that comes with a header and silencer but don't want to go to the trouble of cutting the fuse to install it. Any ideas???
Old 04-09-2003, 03:38 PM
gachezem
My Feedback: (20)
Default muffler for Bully
A G38 muffler fit's the bully, but hard to find one that is really a muffler, most of them are pretty loud.
Gary
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
