DA 50cc and Oil to be used
Old 06-29-2006, 06:17 AM
xtdsm
Default DA 50cc and Oil to be used
After I am done breaking-in the engine, would it be a good idea to run Maxima K2 fully synthatic oil, it seems that's all what we have here available (United Arab Emirates) and if it's not a good idea, can I drop my petrolum based oil ratio (now running at 32:1) and if yes to what ratio.
thanks a lot
Old 06-29-2006, 05:53 PM
karolh
Default RE: DA 50cc and Oil to be used
If you want to switch after the break-in to a synthetic oil which will give superior protection, then the Maxima which is a good quality oil will do just fine. Just use it at it's recommended mix ratio and have fun.
Karol
Old 06-30-2006, 07:52 AM
xtdsm
karolh, thanks a lot for the reply bro.
I am glad that the Maxima K2 oil will work, but my other questions is use it at what ratio, on the bottle is says use it at 20-60:1 and to me that's a lot to chose from, what do you guys think I should go with, what ratio that is?
thanks
Old 07-01-2006, 10:59 AM
xtdsm
anyone!
thanks guys
Old 07-01-2006, 12:37 PM
karolh
Any ratio in the upper half of that mix range will do quite nicely, but I would suggest that you use either a 40 or 50:1 mix. I use Bel Ray's MC-1 mixed at 50:1 in all my gas engines.
Karol
