DA50 VS G62
#55
My Feedback: (62)
UT
RE: DA50 VS G62
RTK, the Sukhoi is done but I had to replace the hatch. It is due in next week. I suffer from the same thing you do... lack-o-time but I'm going to bust out of that excuse soon if I have time
Here are some Pictures of the Sukhoi at Castle this last May. And yes... the pilot will be set forward more when all is said and done.
#59
My Feedback: (10)
RE: DA50 VS G62
ORIGINAL: winger1955
Thanks for the video. That was some good flying. My questions are: How much pull out is there? It didnt sound like the motor was real high in its rpm range but I never saw a vertical clilmb out of hover. What percent throttle is it requiring to hold hover? Any idea what the planes weight came out too? It said stock g62....So is that not even the lightened version?
P3ripperfw
P3ripperfw
I've got another video taken several years back with me hovering my 20 lb. Giant Stinger with a stock G62, B&B muffler, and Mejzlik 22x10 prop. With that combo on a 95 degree day, there was very little left to pull out with. You can hear the G62 screaming away in that one. BTW I had tached that G62/Mejzlik at 7700 one time.
#61
My Feedback: (10)
RE: DA50 VS G62
ORIGINAL: Silversurfer
The B&B is pretty much little more than a side mount 90 degree turn with a whole bunch of restriction.
#63
My Feedback: (10)
RE: DA50 VS G62
Here's the video of my 20 lb. Giant Stinger with a stock G62/Mejzlik 22x10 prop just for sound comparisons......
http://media.putfile.com/Franks-Giant-Stinger
#67
RE: DA50 VS G62
I keep hearing about the great service from DA on their engines. I read on here that DAs break down a lot. I hardly hear of G-62's having to be sent back for repair. It seems to me that the G-62 is far and away a more durable engine. Anyway I would take one of Ralph's converted G-62s over the overpriced DA 50 anyday.
#68
1 Post
RE: DA50 VS G62
ORIGINAL: BBOwen
Just a thought
#70
RE: DA50 VS G62
The stock Zenoah muffler is a bit on the heavy side being steel. Bisson is a lot lighter than a Slimline smoke muffler. If you're into smoke, all you need is the nipple that comes pre-installed on the Bisson. The smoke stuff in the Slimline is not needed on a gasser. Gassers don't need a smoke coil.
As for not many Zenoahs in use, up until recently there have been more Zenoahs used in large warbirds than about anything out there. The two biggest players in the warbird/scale group had been Brison and Zenoah with Zenoah holding the edge in numbers.
#71
CO
RE: DA50 VS G62
Pick an engine that tripes your trigger, its all good.
#72
My Feedback: (29)
RE: DA50 VS G62
The part that is failing on those DA50s is the lower rod bearing. This seems to be a reoccurring theme every time a MFG tries to save 3oz. by using a cantilever crank. They all make the same mistake by using a standard 3 piece crank with the back half removed. A really good one piece crank could be made but its too expensive for these small manufactures, they would have a lot more money in the crank than they have in that pretty case that sells so well. The DA50 looks and runs good, they just didn't put the design effort or manufacturing investment that the Europeans did. The ZDZ crank is very nice but could have been even better with a stiffer design.
#73
DC
RE: DA50 VS G62
I don't see how anyone can say a DA50 is stressed more than a GT80 turning 12,000 rpm in a race plane
Maybe if DA50 owners would use a prop that didn't lug it down so far the bearings would last longer..Like running a car in high gear up a steep hill..
Just because the engine WILL turn a big prop doesn't mean it should be run that way...
Nobody removes the back half of a three piece crank to make a cantilever, it needs the back web for the weight..ALL cantilever cranks are made just for the engine...It's cheaper to make a cantilever than a three piece crank anyway..No need to make 2 parts EXACTLY alike and press a hardened steel pin between the parts...
Cantilever cranks got a bad rep when A&M tried to do it...Wasn't the fault of the cantilever, their three piece cranks were junk too...You can't skimp on bearings and materials...
#74
RE: DA50 VS G62
If turning R's was so hard on an engine then turbines would be a disaster. I also believe that turning a small prop fast is easer on an engine crank & bearings than a large prop in 3D. Of course pistons & rings is a different matter, but that is not where the engines are failing.
