GN2 Oil - Ashless?
I'm having a hard time finding 2-stroke ashless oil to break in my 3W. A local motorcycle shop thinks Honda's GN2 2-stroke oil is ashless. I've called different shops that carry the oil but they don't know for sure. I've also tried looking on Honda's Web sites but am not finding an answer. Does anybody know if it's ashless or not?
Thanks.
Dan
Thanks.
Dan
Try penzoil air cooled oil or any quality non-synthetic 2 stroke oil for your break-in. Mix at 32:1 or 40:1
Dan
IN
Ashless is the wrong oil for air cooled engines. Ashless oils were designed for constant rpm water cooled boat motors. Use nearly any low-ash petroleum oil made for air-cooled two strokes. Penzoil, Quaker State...etc.
Dan
My Feedback: (29)
Its too bad they gave a brand name instead of a specification. The only oil that is truly ashless is TCW-3. Just find a cheap JASO oil and use it forever. These engines are low performance, operate in very dusty environments, and never accumulate many hours before they are destroyed, why get picky about oil.
That same tip sheet also tells you that you can use their brand name synthetic at ratios up to 80-1. You can, but only if you want a short lived engine, even at 50-1.
Dan
My Feedback: (392)
MN
It seems we forget what the original question was, what ashless oil to use for BREAKING-IN. Not what oil to use AFTER breaking-in. Oil such as Lawnboy ashless oil or Ryobi ashless oil at 40:1 is what is suggested by 3W. Lawnboy ashless oil can be had at Wal-Mart or other discount stores and lawn-mower shops.
For us newbie’s, it is very frustrating when we cannot stay track with the original questions.
SORRY, just my two cents worth.
IN
Ashless oils are the wrong oils for air-cooled motors during break-in or any other time, despite what 3W or DA advise. What is meant by an ashless oil? It means the oil won't produce an ash in a specific test when the oil is burned in the laboratory. The ash is a byproduct of the type of detergent package in the oil. The ashless oil detergent package keeps the plug from whiskering when a boat motor is used at constant speed. It is not a high-temperature detergent package, it is a low temperature compatible detergent for water-cooled engines only. Low-ash oils contain a different detergent package designed for high-temperature running in air-cooled motors - that detergent leaves a little more ash in the laboratory combustion test. Our air-cooled engines operate at higher temperatures than water-cooled motors, and do not operate at a constant rpm where plug whiskering might be a problem. Somewhere, some how, DA and 3W started the nonsense with the ashless oil recommendation, and it propagated like folklore. Recently, DA retracted their recommendation for ashless oils.
I've been re-visiting oil ratings and classifications of late. None of the TCW-2 or 3 rated oils are what we want or need for air cooled engines. The Japanese recognized this some time back and performed a lot of in depth testing and came up with their own rating system. JASO rated oils are much better for our purposes.
"Ashless" oils are generally not good for air cooled engines, creating and leaving a lot of carbon inside the engines. As for why a hobby engine manker might suggest such oils, consider that only the large engine manufacturers are prone to performing oil testing. The rest simply read a few engineering spec sheets and go form there. Few, if any, model engine manufacturers perform any in depth oil testing. They don't have the budget for it.
