Fuel Mix ?
Fuel Mix ?
Hi I have a allmost new BME-50 and a new DA-50 the BME says to run on 50:1 mix and the DA says to run on 32:1 can i run both on the same mix and if so what mix can i run them on?
RE: Fuel Mix ?
Pick a high quality synthetic oil. Pick one that is from a manufacturer that is always easily and locally available and does not require special ordering. Mix it at 50-1 and go fly. When you get some time behind you start experimenting if you have the desire. There is quite a bit of latitude in mix ratios for those that understand how things work. Forget all the instructions for using ashless and dyno based oils at dense oil ratios. You want to break the engine in, and the best way to do that is by flying it.
