Let's try again DL-50
#2502
My Feedback: (24)
RE: Let's try again DL-50
ORIGINAL: Edwin
Okey dokey,
Here ya are.
Edwin
Edit - First picture shows the arm and cast piece. The third picture shows the shaft offset.
Okey dokey,
Here ya are.
Edwin
#2503
My Feedback: (198)
Well, that's interesting. Both of mine have BOTH the choke and throttle arms on the same side. Yours seems to have the choke on opposite side from throttle. That solves a dilemma that I wrestled with on my installs, but introduces a new one if you have to flip the carb.
Looks like a carb configuration change to me.
#2504
My Feedback: (24)
ORIGINAL: aerobob
Bob, look back a couplel posts, he flipped the choke arm around
#2508
My Feedback: (198)
ORIGINAL: jrjohn
I'm not sure whats hitting, I thought I tried to do the same thing years ago, and it wasn't possible. I don't remember why
ORIGINAL: Edwin
Okey dokey,
Here ya are.
Edwin
Okey dokey,
Here ya are.
Edwin
#2509
My Feedback: (24)
ORIGINAL: aerobob
Was it due to the change in the plate location in the throat? That flipping it made it interfere with something in the throat??? I can't recall, honestly, but vaguely remember something...
ORIGINAL: jrjohn
ORIGINAL: Edwin
Okey dokey,
Here ya are.
Edwin
Okey dokey,
Here ya are.
Edwin
#2510
Wow, lots of replys really fast.
Aerobob,
I think so. The C clip doesnt sit flush anymore like it did before I flipped it. I thought I read awhile back that someone had done this before. I may be mistaken, or am I the first. This layout would simplify my install quite a bit, but if I cant do it I can still setup the linkage. Its not a show stopper. If the cast threaded piece can be cut off, I'm good. You can see the collision in the first picture, the back of the arm hits the cast piece with the threads in it. The second picture shows it but not as clear. The third picture shows the shaft offset with the C clip about 1/8" away from the body.
Clear as mud?
Edwin
Aerobob,
Clear as mud?
Edwin
#2511
Banned
"IF" the only problem is that cast bracket it can be removed with a dremel. It serves no useful purpose in this application. It's cast on there for other (weedeater type) applications. Can't recall for certain but it's either for the air cleaner bracket or the throttle cable retention clamp on a weedeater. In either event, it's extraneous. Are you using a manual choke or servo?
#2512
Just took another look. The other side of the throttle shaft has a collision also. With the choke open the bottom of the ball link threads hits the shaft stop plates on the other end. See picture three left side. I'm sure that could be cut also. But then we run into the problem of going over center. Servo throttle throw adjustment becomes critical at this point. Other comments! I might pass on this mod for this plane since the engine is new and under warrenty. What do ya'll think.
Edwin
I just cant seem to leave things alone.
Edwin
#2513
AL
To all, He removed the choke plate, releasing the choke shaftin the barrel of the carb,removed the choke shaft from the carb. turned the carb 180 deg. and reassembled it. Now reverse it to the way it came from the factory. remove the screw from the throttle shaft ( the one holding the linkage arm) take the linkage arm and rotate it 180 deg. with the engine inverted, the throttle arm should be up and the choke arm should be pointed down.
#2514
My Feedback: (24)
ORIGINAL: Edwin
Aerobob,
Clear as mud?
Edwin
Aerobob,
Clear as mud?
Edwin
#2515
Banned
Well you'll have to pass it on to Walbro because they make all of these carbs and I don't believe they make one specific to this application. Could drive costs way up. John, he could solve that problem by placing a short plastic sleeve over the choke rod between the carb casting and the e-clip to take up the space. If he is using a servo the detent ball and spring would no longer be needed.
#2516
My Feedback: (198)
ORIGINAL: Edwin
Edwin
Edwin
In my past experience of removing the choke plate attachment screw, those screws have been swaged slightly after being inserted from the factory. Removing the screw permanently damaged the theads in the shaft, resulting in a "false tight" when I reinstalled the screw.
The results were a disaster, and taught me an important lesson.
Maybe this particular carb choke shaft plate screw is not malformed when installed; but maybe it is. I am not of the gambler vein enough to try it again after the first dismal failure.
Sorry to be a downer.... but that's my story and I'm stickin' to it. I still remember the damage to that engine piston, sleeve, and crankcase. Ugly.
#2518
My Feedback: (24)
ORIGINAL: aerobob
I'm sure I'll get unloaded on for this comment, but what the hell?
ORIGINAL: Edwin
Edwin
Edwin
#2519
AL
Here is a before and after picture. Both arms pointing same direction is factory. choke arm down, throttle arm up. This also puts the throttle in a servo pull situation. Factory would be a push.
#2520
Banned
LOL, Okay, Just to give Bob grief, it's called a 'disrupted thread'! LOL But you are absoulutely right. The steel screw will damage the thread while backing out. To what extent you can only determine after doing it but the odds are it is a #2 fit and has quickly become a #3 fit. There are ways to fix it but they are too lengthy and technical to go into here.
#2521
My Feedback: (24)
ORIGINAL: Lou55
#2523
My Feedback: (24)
ORIGINAL: Lou55
I've done several of them with red loctite after removal, You will have a harder time getting the screw out with red loctite than when it was new with the disrupted thread.
#2524
My Feedback: (198)
"Disrupted thread"..... glad I know the name.... I'm quite certain that I had NO idea what those brown lumpy things in the yard were called when I was a toddler, but I learned pretty quickly that I didn't like 'em.....
Same with the choke plate removal.
It *may* be able to be done safely by others, but with the risk of failure, and severe engine damage (which absolutely would not be included in warranty, I'm sure), I would never suggest to someone to do it.
To someone who *has* done it (edwin), I'd cough up a few bucks, get a brand new carb, figure out the linkage, and rest easy knowing you don't have a screw that will vibrate loose at a most inopportune time, destroying your engine, and quite possibly your airplane.
I'm old enough to know which battles to fight, and which risks to mitigate, and which to absolutely avoid.
This is the latter....
#2525
Moot point now. I decided not to do the change. And yes, it was definately swaged (or whatever) so it got red loctite. I could a swore someone did this before. Anyway, its all back together now and back in the plane. Its going in a GP Yak54 which is just going to be a practice plane for me. The engine could end up in a mustang a year or two from now. Or better yet, two DL50's in a Z P-38. I can hear it now.
Edwin
Edwin
