Let's try again DL-50
#1429
AR
RE: Let's try again DL-50
ORIGINAL: Edwin
WOOHOO!!! Mine came today. Are ya'll leaving the return spring on the butterfly?
Edwin
Edwin
I didn't know if the servo would hold up and it would be a constant current draw even at steady throttle positions.
#1431
My Feedback: (22)
Hello Dl50 users,
I got mine, removed DA50 from my GP YAK and bolted the Dl50 on it, Regular gas and 32:1 with MSC 22x8 prop. Choked it and flipped, started in few flips, ran on the ground for 3 times 15 minute runs on idle, idled nicely, checked throttle response, was good, engine was running fine without touching any needles, So, I took the plane up, flew the plane at about 1/3 throttle for about 5 flights of 15 minutes each. No problems so far, so after running it for this much, I thought I'd try giving it some power, when it is flying level, it will throttle up no problem, however, when I attempted a loop, it wanted to cut off on the top of the loop, backed off on the throttle and it recovered, tried that a few times and on the last flight yesterday, it did quit, The engine so far has about 3 hours of runtime, most of it on idle to 1/3 throttle, no needles touched so far.
Is it a bit lean on the high end or what? I am new to gas don't touch needles for nothing. Need expert's help.
Thanks in advance.
Maqsood
Thanks in advance.
Maqsood
#1432
AR
I may have misunderstood, are you saying this is the first time you went past half throttle?
Did you do a wide open throttle run up before taking off?
Does it burble and sputter or did it run real pure then quietly sag till it quit?
If it's stumbling and stuttering it's rich, if it tries to die or dies on throttle up from idle it's lean on the low end, if sags down and tries to die or dies at wide open throttle it's lean on the high end.
Fear not the screws, as a starting point you can turn them in and count the turns, seat the screws very lightly as to not damage the carb. Then back them out to where they were, write the numbers down so you can get back to where your at or use the factory 1 3/4 high, 1 1/2 low as a starting point.
#1433
Banned
ORIGINAL: paul5992
What are you guys useing for an on off switch? Will a regular old reciever switch work? I went to rcexl's websight, the maker of the ignition, and it said that the ignition will draw 800 milli amps at 8000rpm is that to much for a reciever switch?
#1434
My Feedback: (22)
Hi Stickbender,
Thanks for the reply. Yes, I had not run it at full throttle. It was running fine as I was only flying it at 1/3rd throttle before. So, after your post, I took the plane out today, ran the motor and went full throttle, it sagged and wanted to die, so seemed like lean on the high end, so I richened the needle about 1/8th of a turn, tried again and it ran perfectly. Did one flight, and no more problems running full throttle maneuvers.
Thanks again.
Maqsood
Thanks again.
Maqsood
#1435
My Feedback: (17)
Some people talk about setting the high speed needle to drop about 200rpm. Can anyone tell the difference between dropping the rpm 200 and tuning for max rpm when flying ? To get the 200rpm drop, are you doing it by richening or leaning the mixture?
#1440
CA
I hesitate to bring up the subject of the DL50 mount again, but I am looking for some suggestions or advise. I would appreciate hearing from anyone, but would especially appreciate a reply from one of the DL50 experts like MFUESE.
In the pictures below you see a 3mm thick, aircraft grade aluminum plate. It is CNC cut to exactly match up with the rear plate of the DL50. My idea was to strengthen the mounting ears and give a stronger (more bad-landing resistant) base to mount either the stock DL50 mounting brackets or a set of standoffs.
Please let me know what you think. Is there likely to be interest in something like this?
Thanx Rich
Thanx Rich
#1441
My Feedback: (198)
I like the concept a LOT. However, it would be more convenient if it was cutout to clear the carburetor. Installing the plate without R&R of the carb would generate more interest.
Like me, for example.
I'd take one just on principle, if I didn't have to fuss with the carb R&R.
Great idea. Will create enough strength to completely destroy the crankcase if it's a SERIOUS hit.... but that would probably happen anyway.
CNC stuff is cool....
#1443
My Feedback: (198)
Great point! ON my Yak, if I did the DL, I'd *need* nose weight, to prevent re-engineering the guts of the bird, so a little more up there could be a "good thing".
What kind of weight penalty you think? 1.7, 1.8 oz?? Particularly if cutout to clear the carb?
#1446
My Feedback: (10)
IL
It is all nice and good to re-inforce the ears....if you PLAN on crashing. I have had my share of nose-overs and hard landings...actually my Bipe almost always bounces a tiny bit...stiff gear, you know. My mounting ears have held up.
I nosed-over with a CF prop to boot, twice, and it was fine.
I use the DA-50 mounting pattern and the proper length standoffs form DA. I like 1/4-20 throught the firewall.
It seems that plate would nullify any DA-pattern direct replacement, which is one of the selling points of the motor, also.
Gotta go mix some gas.....I am trying to wear this motor out....and not having any success. It takes a lickiin' and keeps on tickin'...ala TIMEX watches.
#1447
AR
Problem solved, it was just a fouled spark plug. I think the moral of the story is: Have a spare spark plug. I have 6 spare plugs now. And the CM-6 seems to wobble a little less in the head.
I don't know if the problem was my race gas mix or the motorcycle oil with castor oil in it, but I will say without a doubt don't use either. It was probably a combo of lead and castor that fould the plug. It runs just as good maybe better on plain old pump gas.
Thanks to Bob a dlusa.net , now I will have a spare pickup sensor if I need it. Same day service, same day shipping, I can't complain about that. Thanks again Bob.
Now back to the screws, I asked because I am so lean on the low end screw. I just wanted to know if it's my air here or if others are this lean on the low end. I'm at about 1 1/2-1 5/8 on the high needle and less than 1 turn on the low. This gives me just a slight burble off idle but clean mid and high. It could be the airflow in my cowl too. I think once I switch to a 23x8 prop it will load the engine enough at low rpm to get it clean all the way through the throttle range.
#1449
MN
Stick bender, it depends on the temperature and altitude, The higher and hotter (temp) the leaner you have to be because the air gets thinner, less air less fuel. Go a little richer than the bog. But not so rich that it has a burble. Where the screws are has little to do with it. I mean if the low end runs good at 1 turn then run it. I haven't run my dl yet but I've been flying two stroke glow planes for 20 years. And the last glow motor I bought and have been running is a 120 os ax, And the needles are set way leaner than what the instructions say and it runs great. Also gas engines are not getting there lube from the amount of fuel running threw it like a glow model they get there lube from the oil mixed in the gas. So if there is no bog and your running the right gas oil mixture then fly it.
#1450
ORIGINAL: paul5992
