Quadra 75 manual
Old 03-11-2007, 02:51 PM
Going Balistic
Going Balistic's Avatar
Default Quadra 75 manual
Does anyone have a copy of the Quadra 75 manual (electronic ignition) in either electronic or hard copy?
GB
Old 03-11-2007, 03:17 PM
Antique
Antique's Avatar
Default RE: Quadra 75 manual
ALL gassers are the SAME..Nothing different about a Q75, use 4.8 or 6 volts on the C&H ignition, 32 to 50 to 1 oil, prop it with a 24-10 or similar, set the carb needles, go fly...
ALL gassers have chrome or Nikasil cylinder bores, aluminum alloy pistons, Walbro or Tillotson carbs,cast iron piston rings, 10 or 14mm spark plugs...What can possibly be any different ?
Some manufacturers will tell you theirs is different, believe it if you want to....
If anyone can document anyhting different, lets have it
Old 03-12-2007, 12:55 AM
gadix
gadix's Avatar
http://www.quadraaerrow.com/quadraaerrow/default.asp
try this one
Old 03-12-2007, 07:49 PM
Going Balistic
Thanks RCIGN1 / Gadix,
I contacted Klaus and he does not have an electronic copy of the manual and there is a charge for the hard copy.
Just looking to do this one on the cheap.
GB
