DL-50 engine
Old 05-31-2009, 11:08 AM
  #4926
Tired Old Man
Default RE: DL-50 engine
Which by itself improves resolution.
Old 05-31-2009, 02:04 PM
  #4927
giddyuperic
giddyuperic's Avatar
Thanks so if I use this linkage and hook up the servo horn part on the hole by the screw and not at the end will this work??? Thank you guys for all of your help. Here is a couple of photo's of my new toy I got for my birthday F9F Panther 70mm EDF with a 14.8 volt battery pack, But as I said this AM I was going to a fun fly and I did. Get a couple of flights in with another plane and bang my phone rings. My kid has got in a fight with her boyfriend and he takes her car keys and leaves her, Long story short I am at home now and I am really pissed But I will fix this throttle thing if it takes all day. Thanks Guys Eric
ID:	1209483   Click image for larger version
ID:	1209484   Click image for larger version
ID:	1209485   Click image for larger version
ID:	1209486   Click image for larger version
ID:	1209487   Click image for larger version
ID:	1209488   Click image for larger version
ID:	1209489   Click image for larger version
Old 05-31-2009, 03:44 PM
  #4928
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
Should help. Takes some pic's of it when it's all done so we an see exactly what you did.
  #4929
Tired Old Man
Sounds like some up close and personal time is in order for the boyfriend. My daughter had one that did things like that. It only took one "discussion" to end any of it happening again.
Old 05-31-2009, 04:56 PM
  #4930
jedijody
jedijody's Avatar
I here crap like that and I thank God for ourthree strappin young men! They have been taught to be gentlemen and know they wouldget just as much or moretrouble from me if they were to pull a stunt like that, that one needs the boot!
Old 05-31-2009, 05:46 PM
  #4931
Bosco2
My Feedback: (42)
Today,
if you kick your kid in the butt for something stupid he can have you arrested and toss in jail,
Old 05-31-2009, 05:54 PM
  #4932
Tired Old Man
Behind the barn where nobody can see still works. Gloves protect the hands from incriminating evidence.
Old 05-31-2009, 06:12 PM
  #4933
craigteffe
My Feedback: (24)
craigteffe's Avatar
ORIGINAL: giddyuperic
Eric,
Install the fiber arm that comes with the engine over the top of the metal one that is already there, be sure to get another4X40 bolt and and install it in the end of the existing arm where you have the Z bend in and get yourself one of these http://www3.towerhobbies.com/cgi-bin...?&I=LXFV40&P=0and install it in the end of the fiber arm. Use 4x40 all thread for your linkage and use one of these at the servo http://www3.towerhobbies.com/cgi-bin...?&I=LXD905&P=0.
Old 05-31-2009, 07:09 PM
  #4934
giddyuperic
Okay guys you know the extra thing that comes with the engine for the throttle??/ Do you just bolt that on or do you hone it out in the same as the metal one that was on there in the first place?? You know the stock one is not round oblong if that make any sense??? So do I just bolt it on there or cut it to match?? I am looking for some batteries for my camera to take photo's and I will get back to you??????
Old 05-31-2009, 07:41 PM
  #4935
giddyuperic
Here is the photo's of what I stuck on now. The green thing for the throttle should it be just screded on or cut it to match the other one that came with the engine???
ID:	1209741   Click image for larger version
ID:	1209742   Click image for larger version
Old 05-31-2009, 07:46 PM
  #4936
mstam1971
The center photo is fine. Drill a small hole where the old connection hole is and fix with a little screw and nut w/ some blue thread locker. Also add some blue loctite to the main screw.
EDIT: Wait before drilling plz. I always use the blue servo arms that come with Hitec servos and leave the standard lever in place. If the hole in the composite lever is round you need to put the original underneath it and drill a tiny hole in the composite one and lock it as described above.
Old 05-31-2009, 08:20 PM
  #4937
giddyuperic
Now before I cut the composite one is that right it shoule match the hole in the stock one? Or can it just be bolted to the throttle shaft with out any problems???? Sorry guys but this is my first gasser and I would like to get this right. What is the reason for putting on the compostie one anyway just because it is longer?
Old 05-31-2009, 08:46 PM
  #4938
FOOPED
My Feedback: (8)
Eric take the screw out of the orginal throttle arm and lay the composit arm on top of the orginal arm and screw the screw back on holding both arms then dril a small hole through the composit arm matching the hole in the orginal arm and use a small bolt there. Then you will have a longer throttle arm using the hole on the composit for your servo to hook to.
Old 05-31-2009, 08:49 PM
  #4939
Richard D Bahmann aka/Wrongway
My Feedback: (42)
Richard D Bahmann aka/Wrongway's Avatar
There is another way... These are nice with a diameter designed to fit on the carb shaft. Has set screw and works great. Comes in 3/4 inch or 1 inch. Most like 3/4 for throttle and 1 for choke.
ID:	1209795   Click image for larger version
Old 05-31-2009, 08:56 PM
  #4940
brewski
I posted some pictures in post #4161 that may help. It is on page 167.
Old 05-31-2009, 09:20 PM
  #4941
giddyuperic
Okay guys I think I have it with the composite arm. Now witch linkage should I use and I thank all of you for your help. Thank you very much. Eric
ID:	1209813   Click image for larger version
ID:	1209814   Click image for larger version
Old 05-31-2009, 09:27 PM
  #4942
mstam1971
I vote for the bottom one in the center image.
Old 05-31-2009, 10:10 PM
  #4943
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
Bottom is the one but go back and do what FOOPED said. You need another hole in that composite arm. Then bolt it toshorter carb arm. Otherwise it will rotate on the throttle shaft.
PS: Came back toexplain in more detail. You will actually end up using both arms. You will use the short metal one that came with it and the composite one will be bolted on top of that metal one. They will share the same screw that goes into the throttle shaft (it may need to be a little longer. A 4-40works good in this hole). BUT you will need one more screw and nut (4-40) to go through the outer holein the metal one, and the new middle hole you drilled in the composite one. So you will have two sets of fasteners holding the composite arm onto the metal one. Then the third outer hole in the composite arm is what you will attach your linkage to.
Old 05-31-2009, 11:56 PM
  #4944
giddyuperic
Thanks for al the help, This turning into a big pain in the ASS!!!!!!!!!!!!!!!!!!!!!!!! just to set this up. I can hardly keep my eyes oen, So I will try to work on this in the AM Thanks guys and I will let you know how it comes out.
Old 06-01-2009, 02:16 AM
  #4945
McChiken
McChiken's Avatar
Old 06-01-2009, 02:21 AM
  #4946
McChiken
McChiken's Avatar
I completely agree Giddy . I spent 2.5 hrs on this . Decided not to mess with carbon rod and just use all-thread . Does this look okay to all you vets. out there ??? It is in the closed position right now . I already set the end-limits but haven't messed with the expo yet .
ID:	1209949   Click image for larger version
ID:	1209950   Click image for larger version
Old 06-01-2009, 07:06 AM
  #4947
thevirginian
McChiken,
Looks solid to me. Ball links are always the preferred method. No slop and no metal contact.
Old 06-01-2009, 07:34 AM
  #4948
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
ORIGINAL: McChiken
This is worth spending the time on trust me.
The only thing I'd change on yours is to move the servo side ball end one hole in towards the servo. Then you will need to increase your end points to give the better resolution that makes the throttle feel a lot smoother. On mine, if I use that blue hitec arm on both sides the servo side one is always one hole closer to the servo than the the throttle side. So if the throttle arm side is on the 4th hole, the servo arm side should be on the 3rd hole. This gives you good resolution. Try it, I bet you'll like it.
Old 06-01-2009, 07:35 AM
  #4949
Super08
Super08's Avatar
Yup, looks fine.
Old 06-01-2009, 12:32 PM
  #4950
giddyuperic
Man your looks great and does it works as well? You did a nice job. Can you guys tell me witch alum arm works on the carb linkage instead of the composite? What brand please and thanks.
