DL-50 engine
Old 12-05-2009, 05:41 PM
  #5926
Super08
Super08's Avatar
Default RE: DL-50 engine
Hmmm......
Old 12-07-2009, 04:09 PM
  #5927
Indiomike
Indiomike's Avatar
Hi
I'm new to gas powered planes. Just got the 35cc 260 from Areoworks. I'm about to order a DLE55, probably from ValleyView RC. I've been reading quite a lot on this forum and I've got a question. I've seen the term "burble, gurgle, and gerbil (well not gerbil) and I'm not sure what these terms mean in regards to the engine. Is burbling and gurgling interchangeable words to describe a sort of hesitation in the engine as it revs up? I'm guessing that is what it means. If not, what sound do I listen for to identify burbling or gurgling and how is this problem fixed.
Thanks in advance.
Mike
Old 12-07-2009, 04:32 PM
  #5928
JOHNS3D
JOHNS3D's Avatar
Wow 55 on that plane...it will be sick!!!! lol, the DLE55 on my Extra 300 50cc has amazing vertical from hover i can imagine a 35cc with this power.
Old 12-07-2009, 04:46 PM
  #5929
unit53
i can allmost guarantee someone else will add to my response,,,usually the burbling will occur where the engine transitions from idle to midrange,,,usually if the idle or high speed needle is too rich this will occur,,as far as using a 50 cc in a 35 cc plane ,,not just me ,,,but the manufacturer probably will discourage this,,you may have ground /prop clearance issues,and you could rip the plane in half from over powering,,,read the articles on gassers including this whole thread ,for info,,if youve ever had a weed whacker or gas string trimmer and noticed a lag in engine accelleration at around mid throttle,,thats simmilar to the burbling youve heard of ,usually leaning the needles slightly makes that go away,,also if you have friends that have gassers,,get with them ,,it makes it much easier ,in person,,,ps ,,,once again read this thread starting at page one,,,youll be surprised what youll learn.ps alot of our flying is done at mid throttle,so its important to have this adjusted ,,thats even if it occurs,,
Old 12-07-2009, 05:27 PM
  #5930
Super08
Super08's Avatar
Actually the DL works good in this airframe. Myself and others hae done it. There is room for a 22" prop but you do have to watch your landings. I found a 20" three blade worked very well.
Old 12-07-2009, 06:29 PM
  #5931
JOHNS3D
JOHNS3D's Avatar
looks nice!!!!!!!!!! i can imagine that think getting out of hovers... lol.
Old 12-07-2009, 09:47 PM
  #5932
Super08
Super08's Avatar
I can't even begin to explain what the vertical is like!
Old 12-07-2009, 10:48 PM
  #5933
SportFlyer3
I was looking at this combo also (Aeroworks 35cc with DLE 55). There was a review in a mag and the tester was running a DA 50 so I knew it could be done...
Old 12-07-2009, 10:54 PM
  #5934
Super08
Super08's Avatar
To make it fit you need to get shorter standoffs and put the carb through the firewall or remove the firewall and move it back and reattach it. Either way works good. By mounting the throttle servo as far back as you can it will avoid adding any weight to balance it with the DLE.
Old 12-07-2009, 11:11 PM
  #5935
unit53
well ,ill be the first to admit,,after around the time you get used to a new plane
,im allways looking for more power,,and any one should know nothing replaces displacement and where i live above 3k asl.if a 50 cc is recommended a 60 ,,would do better,,,one great advantage ,theese days,,is lighter components and stronger servos and batteries,,allowing us to fly bigger planes with smaller motors,ive got a current 30 pct.yak that weighs 7 pounds less than the same size vintage 1989 ,,model,,of the same scale,,so in retrospect,,its all good.
Old 12-08-2009, 12:57 AM
  #5936
Indiomike
Indiomike's Avatar
Thanks for the response to my question. There is a member at my club that has a DA50 in the Aeroworks 35cc Extra 300 which is the same size and weight as the 260. Other than for takeoff, he doesn't go to full throttle very often. He does not fly 3D maneuvers, just routine aerobatics. It is an impressive plane with that engine. Aeroworks says the 35cc 260 or 300 uses a 35cc to 45cc engine so the DLE55 isn't too far above that. I don't think it will be too much for the plane to handle. I don't want to spend the money that a DA commands. From what I've read I'll be very happy with the performance of the DLE55 at much less cost. By the way, Aeroworks has the 260 on sale for $150.00 less than regular price. I think it's a very good buy.
Mike
Old 12-09-2009, 10:54 AM
  #5937
JOHNS3D
JOHNS3D's Avatar
any video of the 35cc with the 55cc power machine?
Old 12-10-2009, 12:00 AM
  #5938
Super08
Super08's Avatar
I don't, another guy in the 260 thread in the Aeroworks sub-forum does.
Old 12-18-2009, 03:15 AM
  #5939
Indiomike
Indiomike's Avatar
Well I have read all 238 pages of this thread along with several other threads pertaining to the DLE55. I will be ordering that engine from ValleyView RC within the next week or so.
I was going to use Pennzoil Aircooled at 32 to 1 for the break in but recall some folks saying that oil doesn't carry away contaminants or other tiny particles out of the engine very well. I think I will go with Stihl Ultra as that seems to be what Jody prefers. I plan to use the Stihl at 32 to 1 initially and then go to 50 to 1 after a couple of gallons has been run through the engine.
Here is what I'm not too sure of. On the very first startup of the engine, do you set both high and low needles after the engine has run for 2 or 3 minutes or do you just let the engine run at about 2500 RPM for maybe 6 or 7 minutes and then shut if off to totally cool down before starting again. It seems to me that if the high needle is to be set (peak RPM then back off a 100 or so) I will have to have the engine at full throttle for about 15 seconds in order to make that adjustment. I'm worried about running the throttle at full bore when the engine is that new. Is it okay to do that or should the engine be run several times (at low RPM) with total cool down between each run before taking it up to full throttle.
I plan to fly the engine after the first or second tankfull (16 to 20oz tank) for the rest of the break in period. I'll just fly around with lots of varying throttle settings for the first gallon or two of gas.
Please correct me if I'm about to do something wrong.
Old 12-18-2009, 07:47 AM
  #5940
Super08
Super08's Avatar
Personally I set both my needles on the first tank of fuel. I let the engine warm up, set them and then do the first cool down. Most everyone will have their own method.
Old 12-18-2009, 10:12 AM
  #5941
arobatx
I do exactly that as well....let it warm up, tune the needles, then the first cool down of the heat cycling....
Old 12-18-2009, 10:58 AM
  #5942
Indiomike
Indiomike's Avatar
Okay, I'll do it that way.
Old 12-18-2009, 11:52 AM
  #5943
JOHNS3D
JOHNS3D's Avatar
INDIOMIKE, sent you a pm with a good info about brake in..hope this helps abit.
Old 12-18-2009, 12:19 PM
  #5944
hillbillyexpress
CAN YO PM ME THE INFO ALSO PLEASE
Old 12-18-2009, 12:40 PM
  #5945
JOHNS3D
JOHNS3D's Avatar
done.....hope this helps.
Old 12-18-2009, 02:19 PM
  #5946
Indiomike
Indiomike's Avatar
Thanks John
Mike
Old 12-19-2009, 02:06 AM
  #5947
Aussie-Bob
Very neat installation Super08 [sm=thumbup.gif]
I wish mine were this neat !
Old 12-20-2009, 08:27 PM
  #5948
JOHNS3D
JOHNS3D's Avatar
love my dle55....the vertical from hover is just amazing....no dead stick since new.
ID:	1338557   Click image for larger version
Old 12-20-2009, 09:38 PM
  #5949
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
Same here...rocket pull outs and never quits. I have probably at least 20 gallons after over a year of flying. Not a single problem.
Old 02-26-2010, 06:10 PM
  #5950
69 roadrunner
Does any one know the factory settings on the low and high neddle thanks steve
