DL-50 engine
#1353
My Feedback: (17)
RE: DL-50 engine
That's the supercharger. Seriously, it is the battery connection for the electronic ignition on my G26. The conversion was done by Ralph Cunningham. The plug does not go into the crankcase, but rather in the openning at the rear of the engine where the flywheel for the stock ignition was. Ralph mounts his electronic board in that area after removing the flywheel.
#1354
My Feedback: (17)
RE: DL-50 engine
Yes, ACE will have the part. Take the picture with you and show it to a salesman, it will save you time. This picture should make things clearer on installing it, if not let me know.
Chuck
Chuck
#1355
RE: DL-50 engine
Another option is to use a nipple off a glow engine muffler and tap the original hole...a little JB weld ensures no leaks. I copied some others that run the tube to an 8mm film cannister in the fuselage, making sure it wasn't airtight
#1356
My Feedback: (198)
RE: DL-50 engine
If you use the pressure tap install, you must be absolutely sure to grind off any protruding threads on the INSIDE of the cover, and that the modification is done with the cover removed. Someone who is unfamiliar with these carbs HAS tried to do this while the cover was still installed, and it turned ugly really, really fast.
My method is to remove the cover, drill with a 1/8" drill, force fit a short piece of 1/8" brass tube into the hole, silver solder it in place, clean the inside, done.
I have done this on every engine I've owned, because all exhibited some degree of unwanted pressure variations due to cowling and airflow around the carb. To me, this is "the" "midrange" fix when things act different in the air than on the ground.
#1357
RE: DL-50 engine
this is sweet news guys one thing I would like to know, do you have to careful when you take the cover plate off will anything pop out like a spring and if so how do you put it back
#1359
CA
RE: DL-50 engine
You should be careful removing the plate because there is a rubber diaphram under the plate that can be damaged with rough handling. But dont worry, nothing should pop out. I would do the mod on any gas engine, whether the carb is on the side or rear.
#1362
My Feedback: (17)
RE: DL-50 engine
Cambo,
Just pick a drill size that fits comfortably inside the brass fitting. There is nothing critical about the hole size because there is a very low volume of air passing through it. Just don't make it smaller than the hole already in the cover. Remember to plug the existing hole with some silicone before reinstalling the plate.
Chuck
Chuck
#1363
AZ
RE: DL-50 engine
I want to thank everyone for all the help. I found the fitting that chuck was talking about in the plumbing department at ACE. I tried soldering it on but really couldn't get the solder to stick to the plate. No matter, a little JB weld did the trick. . I am anxious to try and fly again as it looks like this just might work.
#1365
RE: DL-50 engine
ORIGINAL: thedanimal
im looking into putting a dl-50 in a wild hare 28% extra 300s, dose the dl-50 have the power as a DA ,& will it be to nose heavy?
Cheers
Pupmeister
#1366
My Feedback: (119)
RE: DL-50 engine
OK fellas-- fired up my first DL50 today. Airframe is a GP Ultimate. Dollar for dollar I think it is one of the better deals around. Of course that is easy to say after one tank. Fuel draw was a problem to start as it took 15-20 flips to get a pop, then another 10 or so to get it running. When it started running-- boy did it run. Lawn Boy @ 40:1 and a Wild Hare 22/8 prop was at 6900 RPM after some running and tweaking the needles a bit. The low end was way-- way too rich-- high end was close. Keep in mind this was at 52 degrees (you could see your breath) and 1 hour after a thunderstorm. The air was damp, cold, and very heavy--and still got a max of 6900 on the first tank--idle was 1700, but it shook the airframe pretty bad. It should be noted that I only had the bottom wing attached.
Not bad for $400.
Not bad for $400.
#1367
My Feedback: (198)
RE: DL-50 engine
AJF-2 - REALLY glad you're part of the happy users of these. I've been following these since the beginning, and except for some initial growing pains in a very few engines with carbs and mounts.... it's a challenge to find bad press about these.
I am SURE happy with mine, and for the money, just an untouchable value.
#1368
RE: DL-50 engine
Picked up some brass nipples at the hardware store today. I think I will go ahead and to the vent mod to both of my DL's now while I am putting my planes togerther instead of getting out to the field this spring and find I have problems. Here are a couple of quick pics of my install so far in a GP Wagstaff. All the stuff on the cowl is dust from cutting the fiberglass and I hadn;t wiped it off yet. My other one is going in a Giant Stinger.
#1370
My Feedback: (42)
NC
RE: DL-50 engine
Well yesterday turned out to be a good day for me, I took my Christen Eagle up for the first time with the DL 50 in it, and they both perform very well,
The engine that was runing a bit rich was consistence with plenty of power and the plane was fast and responsive it was great,
I did notice that the engine that I ran in my back yard doring the week did very well but I did notice a diferrence in performance when I added the nipple and tubing to the back plate of the carburetor Friday night
it seems to me that it ran mutch smoother and not as poppy, all in all I was very pleased with the engine performance as well as the CE it self,
#1371
WV
RE: DL-50 engine
ORIGINAL: Super08
Question for you all. What is the minimum safe distance to keep the plug wire away from the exhaust when routing it through the cowl?
Earle
#1372
My Feedback: (17)
RE: DL-50 engine
ORIGINAL: Bosco2
#1373
RE: DL-50 engine
I always liked the Christen Eagle. It just grabs your attention as soon as you see one.
Thanks Earle, I'll have to look and see if I have enough room to route it between the muffler and the cowl. I would like to get it inside for both looks and so it;s not out flapping in the wind.
#1374
My Feedback: (36)
TN
RE: DL-50 engine
Hello Dl owners, today I had a disturbing event with my DL A seizure in flight rock solid. I use 50:1 amsoil I also own a DA and BME using the same mix. Bob told me to send it in. It has always made a rattle noise at TDC and then at BDC. I will keep you informed the engine rated up there with my DA great power nice idle at smooth transition. so no complaints. I hope it get taken care of was purchaces in sep 07. later Hog
