Rebuilding Grandpa's Plane
GA
RE: Rebuilding Grandpa's Plane
Lou55,
I haven't taken anything out really. Just the fuel tank, lines and the foam packed around it to get the tubing diameter and look at the condition of the kill switch. An I've pulled the carb off to inspect it. I'm not going to pull anything else till I have the parts to replace it. Plus, the old servos will give me a guide to the control throws.
I plan to document as much as possible. I'm sure I have photos of him and the plane someplace. I know I have video of him flying some of his other planes.
GA
He told me it was his own design. But it dose look like variation on the Lazy Ace. The wings are clipped to 70" the airfoil is semi-symmetrical and the stab is flat and not air foiled. The arrangment of the cabane struts is different too. It's slab sided...not stick built...it's very sturdy. It's quite possible he started with the Lazy Ace plans and made modifications to make it more aerobatic. I know he was very familiar with RCM plans (we all were...are.) I remember he built a Desperado 3000 and got a big kick out of how strange everyone thought it looked.
http://www.rcmmagazine.com/store/sto...ArrY7wrCE3G1H3
I'll post some more general pictures of the airframe tomarrow when I can take it out in the yard and stand back a bit.
My Feedback: (19)
ORIGINAL: meaden
#32
Banned
Does that plane have N-struts??? Sure looks like your Grandfather put mounts on for them. If so, don't try and fly it without them.[:@][:@][:@][:@][:@]
#33
GA
Don't worry I have the struts! Glad you said something though...I put them away for safe keeping. In that safe spot we all have but can't remember where it is
#35
Banned
My Super Stearman was 16.5 and was a bear to land. They come in really fast but slow down really quick due to the additional drag. Keep the speed up on the landing and it should be fine but odds are you'll have to fly it onto the runway.
#36
GA
Back to engine questions...
I got the carb rebuild kit. Anyone have a link to a step-by-step? I think there is only one gasket or part missing but I might as well replace it all while I have it apart. (can ya tell this is the first gasser I've worked on?) I'd also like a reference before I pull it apart so I can get it back togther.
Attached is a photo of the spring on the throttle that looks like it should be attached to something...?
#37
GA
Ok, I found an exploaded view of the carb. I replaced the gaskets. The only thing I found missing was a filter. I didn't touch the lever looking parts...I think there's another filter under them?
Picts of the replaced gaskets and the replaced filter...
#38
My Feedback: (98)
First Grandpa took the spring off the lever so the servo would have to fight it when you open the gas. He left it on the shaft to maintain the spacing of the butterfly valve in the engine. That's a ll cool.
The bottom left Gasket is really little one way valves used to pump the fuel, it goes againist the body of the carb you have pictured on the left. You know it's on right when the two flaps are over holes in the carb body. It looks like if you rotate the carb body 110 degrees clockwise it'll line up. the gasket top left goes over the one below it.
The gasket bottom right goes on the other side of the carb, metal side toward the carb body.
Not sure about the top right.
I saw a site the tells you how to rebuild the carb, and it's theroy, I tire and find it.
#39
GA
ORIGINAL: soarrich
The picture I posted of the gaskets are the ones that I took out. I know that they are critical to making the fuel flow right. I just don't know which does what. I replaced them with the new ones as I took them out. Making sure they were in the right orentation. I'm 98% sure it's good. Like I said that little filter part was the only thing I could see missing.
Not like a glow carb...
#40
My Feedback: (98)
Before you put the motor back together, put a fuel line on the carb with some gas in it, open the side that has the hexagon needle and blow through the tube making sure the gas goes past the needle if you lift it a tiny bit. Screw the two needls for the high and low jets in while counting to the 1/8 turn then back them all the way out and blow gas through them, then put the needles back to the same place. The needle closest the engine in the L lowspeed or idle, the one furthest from the engine is the H highspeed.
#42
GA
#43
My Feedback: (98)
Their fliters are tough to get through!
What action are the Wright's famous for?
If you where really big, you would be a ?
FG is a clue.
I can't believe they even filter the PMs, I thought I was being good by PMing you the link rather than posting it.
FG is a clue.
#45
OR
I agree with LOU55. What your doing is something I'd seen often. Used to be a gunsmith. People would bring in a fine shotgun or rifle and want to reblue or put a recoil on it. That took away the not only the value but also the history of the piece. Don't do it.
#46
OR
the previous note I wrote is probably to late to stop this sin. But all the rest of you guys, when you find some other reliC or antique don't make this mistake. Don't want to make anyone angry but DON'T DO IT!!!!~
#47
GA
Sin? really now...beyond the sentimental value of the connection with my grandpa it's a typical large scale sport plane built in the late 80's early 90's. I have planes that I've built that are pushing 20 years old. If I had no interest in it I could easily sell it at the next swap meet or to a restaurant that would hang it up and let it collect dust. Then the history really would be gone.
Trust me, I understand the value of antiques. I've spent the past few years repairing 18th and 19th century furniture. I also understand the sprit of the time my grandpa spent involved in RC...I lived it with him. Under glass is not where he would want his planes to be. He often asked me if I had flown them after I got back into the hobby and I told him that I was working up to them.
The point of my original post was to get help restoring it to flying condition safely and get information on gas engines (which I'm not familiar with in detail.) Not to get opinions on weather it should be done. Because, in the end, it's my plane. Grandpa gave it to me.
#48
My Feedback: (19)
ORIGINAL: meaden
So Meaden, I say go for it and enjoy that old bipe!! Some old planes can be museum pieces, some should be flown.
#50
I second the motion. I had an old but well preserved C/L Cosmic Wind side profile with a Torpedp 29R green head from the mid 60's that hung on my workshop wall for decades. A couple years ago I met up with an old friend that still occasionally flew C/L and gave him the model.
You can't imagine the joy it gave me to see that old work horse turning laps, not to mention the unforgettable smell of Castrol R burning. It turned 40 last year and is still alive and kicking. Most all planes were made to be flown, if not by you then by someone else.
Karol
Karol
