Is there any simple way to come up with bushings for graupner props to fit the 38 size prop bolt? Can they be purchased pre made? Too bad I don't have a lathe!!
You might try cutting a strip of aluminum from a Coke can and make a shim/bushing out of that. Or, you might be able to find brass tubing that would work.
