Stupidest Question DA-50 Ignition
TN
How do you hook up a DA-50 ignition?
2 Way Switch: One wire leads from OFF and one wire leads from ON
Battery
Ignition Module: Two wires leading from it.
One is large red
One is smaller with only red/black
One wire leading from prop hub area
too dumb to figure it out
Battery
One is large red
RE: Stupidest Question DA-50 Ignition
Ignition to switch. Battery to switch. Ignition lead to engine hall sensor. You have to adapt the wire on the ignition switch to mate to the wire from the ignition, or vice versa as you choose. Think of a switch like it's a pipe with a shut off valve. The battery feeds through the switch, to the ignition, to the engine lead.
