Is there any power to be gained?
Old 06-10-2008, 07:59 PM
RR24
RR24's Avatar
Default Is there any power to be gained?
Is there any power to be gained, from mods or the use of different style intake's ( or carb. adpters)?
THanks Wes
Old 06-10-2008, 09:11 PM
altavillan
Default RE: Is there any power to be gained?
absolutely!
Old 06-10-2008, 09:15 PM
RR24
RR24's Avatar
well are the different things to do ot try?
Old 06-11-2008, 09:35 AM
Jburry
Jburry's Avatar
Smoothing abrupt transitions between intake tract shapes, opening restrictions, increasing intake diameter etc.
Vague answer to vague question.
Engines are just air compressors. More air thru it means more power. Find ways to let the air flow more easily. Everything's a tradeoff, the more power you make with these tricks, the less user friendly the engine will become, as vacuum is reduced at the venturi.
Any specifics? Power is available many ways. Some engines respond to some techniques better than others.
J
