DL55 Sound Levels
DL55 Sound Levels
I'm working on identifying my next setup. Currently planning a Pilot RC Yak 54 (30%) and I want to use a DL55 as the powerplant. the fuselage is preconstructed for a cannister. This is my first gasser, and before I spent $200 on the cannister, I was wondering if anyone knows the typical sound levels with the stock muffler on the DL55. Our field has a 90db@9 feet rule, and if I can stay below that with the stock muffler, I wouldn't mind saving the $.
Brad
Brad
RE: DL55 Sound Levels
Loud and prop dependant. If you want quiet you will need a cannister, and do some prop experimentation to find the one that works best with your airframe. That description fits about all the other gassers using "directive" exhaust components. I deliberately did not call them "mufflers".
AZ
My worn out DL50 from the "DL50 low compression, low power, bad idle" thread was 101 i think at full throttle with either a xoar 22-8 or 23-8 (can't remember exactly). Thankfully, we are on the indian reservation and the closest home is over 1/2 a mile away. Actually, that home was complaining about noise. Eventually we got the police involved and asked them to check the sounds levels at the house. Turned out the lady was primarily complaining about the full scale airplanes on approach for both Phoenix Sky Harbor and Scottsdale Air Port.
My DL-50 with stock muffler is not necessarely quiet. But I wouldn't want to call it especially loud either. A canister is definitely the ticket if you look for a quiet set-up.
So looks like I'll be going with the canister. Can someone explain to me why a few ounce of stainless steel and a couple of welds cost $200??
Brad
Brad
AZ
I made one once that basically started as two bud light aluminum bottles. They where sand blasted to get the paint off and combined to create multiple chambers. I never hooked it up to a my DL but I got a 46ax so quiet that it sound like an electric from 3ft away.
My Feedback: (98)
ORIGINAL: bkdavy
I've been looking at those designs, but trying to find the metal bottles is not easy, and I don't have a brazing or welding rig.
Brad
Brad
Or try this, very mellow sound.
They charge that because they can. If you tried to have the same or similar product made on an individual basis at a machine or muffler shop the tab would likely be closer to $600.00 and up. They don't sell thousands of them, which is what it would take to get the price lower.
My Feedback: (98)
ORIGINAL: soarrich
Go to the beach, those are the areas where you'll find aluminum bottles.
ORIGINAL: bkdavy
Brad
Brad
My Feedback: (98)
I have a C-60 on my MT57, and if I remember correctly there is a 200rpm loss on the top end. It has a very nice mellow sound and is easy to fit in the plane with the flexible header.
I found a Vess 22a was very loud, ripped a lot. 23x8 TBM very quiet, but really pulled the rpms down, but flew OK. The Xoar 23a was quiet, and flew very well. NX23x8 flys the best, is a little louder than the Xoar, much quieter than the Vess, it has a nice sound to it, not quit a rip.
