DLE-30 - Post your prop data here
#51
My Feedback: (42)
DL-30 two gallons (loaner from friend) Sea Level 60 degrees F with Velocity Stack
JC Super Prop 20x7 = 7000 rpm solid
I took the loaner off today and put my NIB DL-30 on there and will be curious what the same prop does on the first tank or so. Might go down to 18x8 for break in.
#53
AB, CANADA
Brand new DLE 30 with only 12 ounce through it.
-solid 1500 rpm idle
-Mejzlik 18x10 7950 hot
-Xoar laminated 18x8 7800 hot
It will only get better from here....
#54
ORIGINAL: Super08
Thanks. What airframe are you using with the 30?
#59
AB, CANADA
Thanks John, here is a link if you're interested...
http://www.chiefaircraft.com/rcmsec/...C/Extra26.html
#61
NC
hey guys. im about to get a Pilot 26% Yak, and stick a new v2 DLE30 into it. ive been flying 3d for a while now, but this is my first gasser. so ide like to know - what prop should i get to break the engine in with? and then - which prop has been decided as best for 3d flying? (hovers, harriers, blenders, and stuff like that. - lots of vertical.
thanks yall
Helifryer
thanks yall
Helifryer
#63
NC
cool. thats the one that i was planning on going with for flying this baby
(i love xoar props... overpriced, but damn! - they look good
haha)
problem...: Chief has that prop temporarily out of stock.
but they do have a vess 19" prop in the 19A and the 19B. anyone know if either of those compare to the xoar 19x8?
thanks
Heli
thanks
Heli
#70
My Feedback: (14)
Temp 56 degrees, 32% humidity. sea level
30:1 oil, 64 oz of fuel thru it.
Vess 19A 7900 rpm peak.
This is with the CyberPlate rear induction conversion.
39 degrees 79% humidity.
APC 18x6W 8700 peak
Read more: http://www.rcuniverse.com/forum/m_96...#ixzz0pnfp8wZe
APC 18x6W 8700 peak
#72
Maybe a little harder to hand start due too poor fuel draw. I love the way I can tune it when running. It reves up instant with a 18x10 wood M.A. on it. The install is maybe a little more difficult....but it is my first rear carb install. I am glad I did the rear conversion. I think the transition is smoother in RPM levels. Capt,n
<hr />EDIT...I am going to fix that poor fuel draw while I got the engine off. I am going to solder that hole in the choke plate like Jody said. Thanks Jody for the good idea. Capt,n
#73
NC
ok yall... heres a dumb question:
what is an acceptable throttle servo for this engine? does it have to be MG? how many oz. torque?
thanks again yall
Helifryer
thanks again yall
Helifryer
#75
AR
Am thinking about a DLE 30 on my Funtana 90 - my present engine really doesn't do it. G20. I have a ground clearance concern. Any ideas on a 3 bladed 3D prop for this motor??
Thanks - Ron
Thanks - Ron
