G26 vs G26EI
My Feedback: (10)
RE: G26 vs G26EI
ORIGINAL: Muroc1
Is there anything that seperates the G26EI over the G26? Is the extra $50 worth it to get the EI?
Frank
Frank
You wont gain any power by going with the EI. The EI will make it easier to start and maybe a little better idle. The G26 Mag is a better choice if your building a warbird as you'll need the extra weight up front. If your building a sport type plane or one for 3D then you would want the lighter weight EI engine. Zenoah has proven themselfs over the years. Both are good engines.
RE: G26 vs G26EI
And just in case that power hungry Zenoah ignition ever goes south on you just opt for an RC exl ignition as a replacement from CH Ignitions or RC ignitions, as either are straight forward plug and play.
Karol
Karol
