Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
Reload this Page >
ZDZ 80 ignition convertion to Dl or DA ignition
Old 06-22-2010, 08:34 AM
basimpsn
Default ZDZ 80 ignition convertion to Dl or DA ignition
Well after searching RCU for a fix to my very hard to start ZDZ 80RV engine and some time dead stick landing. I came to one conclusion . My ignition system.
So i did a complete ignition convertion using the convertion kit from (Agape Racing) works great. Now I have a second zdz 80 with the same problem that need converting,, But wait, I have a damage Dl 50 engine with a good ignition system. Here is my simple mod to the old ZDZ 80 sensor and wiring that works very good.
ID:	1456875   Click image for larger version
ID:	1456876   Click image for larger version
ID:	1456877   Click image for larger version
ID:	1456878   Click image for larger version
ID:	1456879   Click image for larger version
ID:	1456880   Click image for larger version
ID:	1456881   Click image for larger version
ID:	1456883   Click image for larger version
ID:	1456884   Click image for larger version
ID:	1456885   Click image for larger version
Old 06-22-2010, 08:59 AM
basimpsn
Default RE: ZDZ 80 ignition convertion to Dl or DA ignition
More mod pictures
ID:	1456889   Click image for larger version
ID:	1456890   Click image for larger version
ID:	1456891   Click image for larger version
ID:	1456892   Click image for larger version
ID:	1456893   Click image for larger version
Old 06-22-2010, 09:56 AM
Super08
Super08's Avatar
Could have gotten an insert and retained the RCXL cap and used a CM-6 plug as well. Converting the ignition on these engines make a good engine even better...
Old 06-22-2010, 12:16 PM
basimpsn
So true
