SPE-26cc not responding to throttle input
I have a SPE-26cc that I just had a guy rebuild the carb and I just replaced the ignition module with the RC Excel module. I have the timing at 28 deg (btdc) and have the high end needle out 2 turns and the low end out 1.5 turns. The engine will start easy and idle, but when I increase the throttle the engine does not increase rpms at all. Any help will be greatly appreciated.
IL
RE: SPE-26cc not responding to throttle input
Make sure the carb is getting pulse from the engine and that the butterfly hasn't been flipped over to the other side by mistake, i have an spe 26 it is a great engine.
