Wiring For a Rcexcel Kill Switch
FL
RE: Wiring For a Rcexcel Kill Switch
Smart-fly stuff Great !!! My favorite!!
The RCExcell cutoff switches work well too. You can install a manual cut off switch between the power source and the switch as stated above.
FL
[link=http://www.rcaer.com/pages/Articles_and_Formulas.cfm]Article #8[/link]
The RCEXL switches are good! I use them exclusively.
Click above.... go to Article #8. It will show you how to set up the RCEXL cut off switch... Easy easy..
Cheers
Henry
Cheers
Henry
1 Post
ORIGINAL: BadAzzMaxx
I have sold about 50 of them and have not had one returned.
Milton
Milton
ORIGINAL: DAN REISS
That's not the one you should use. Use this one. Dan.
http://www.smart-fly.com/Products/Ignition/ignition.htm
Why should use the smart-fly instead the RCEXL ?
I know more than 500 satisfied modellers in my country using the RCEXL.
None using the smart-fly (not sold here)
Regards
ORIGINAL: mpascual
Regards
ORIGINAL: DAN REISS
Regards
Because it has to be better, It cost more.
ORIGINAL: mpascual
Regards
ORIGINAL: DAN REISS
Regards
On small airplanes with small gas engines you don't need a second battery for the ignition.
Maybe someone will post saying i'm wrong doing that. But maybe they need to 'change their switch'
Regards
