RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   G26ei Sensor Gap (https://www.rcuniverse.com/forum/gas-engines-142/10075977-g26ei-sensor-gap.html)
mmn 10-18-2010 07:23 AM
G26ei Sensor Gap
Anybody know the thickness of that gauge? I don't have one and I need to set the gap between the sensor and the magnet on the rotor.
Regards
Michael
pe reivers 10-18-2010 08:34 AM
RE: G26ei Sensor Gap
use a postcard. The distance, if less than 0.5mm is not critical at all.
mmn 10-19-2010 12:20 PM
ORIGINAL: pe reivers
Thanks.
Went to the LHS and measured the gauge from a new one in the box. For future reference it's .041 inches.
Regards
Michael
spaceworm 10-19-2010 02:14 PM
ORIGINAL: mmn
Thanks.
Regards
Michael
Which is 1mm.
Regards, Richard
w8ye 10-19-2010 02:18 PM
The standard has been .5mm or .020" for many years but they will mostly work at 1mm or .040"
So now you have a tolerance to work with
pe reivers 10-19-2010 04:00 PM
The Zenoah EI does not follow general rules. Being industrial engines, they need more tolerance. They also draw more than twice the current of a standard engine. so here's to Zenoah:
Overrated
underpowered
overweight
So it makes sense that, in line with Zenoah policy, the EI is overhungry for power. I have reports, that failure rates are about what to generally expect from EI units : 2% to 5%.
apalsson 10-19-2010 05:04 PM
Overrated
underpowered
overweight
RALPH!!!!!! WHERE ARE YOU??????
:D
captinjohn 10-19-2010 08:56 PM
ORIGINAL: apalsson
Overrated
underpowered
overweight
:D
apalsson, now I see how you got your name....you like to "appall" folks...you know...tick them off...stir up trouble........................................... .............
bcchi 10-19-2010 11:12 PM
Overrated
underpowered
overweight
Now you have done it. BCCHI
pe reivers 10-20-2010 05:58 AM
I know [:@],
Those are just the reasons that keep Ralph busy.
