ZENOAH G-62 INVERTED ?
HI
IS IT reasonable to run a ZENOAH G-62 INVERTED as that seems it would be the best way to cover it in a cowl to improve the look of the air framewill i be making it impossible or to much more difficult to start the engine -please only respond if you have been there done that as that would be most helpful BEST REGARDS TONY |
RE: ZENOAH G-62 INVERTED ?
99.9% of all single cylinder engines are mounted inverted.
Milton |
Yep....in fact, it would be rather odd to see a gas engine mounted upright like its smaller glow cousin.
I know a guy that has a giant stick with the DLE 50 upright, and a pitts style muffler. Looks like a Peterbilt. that engine doesnt care if inverted, sideways, or any other way
ORIGINAL: tony0707 HI -please only respond if you have been there done that as that would be most helpful BEST REGARDS TONY |
Been there done that! Have one in a 29% Pitts. Starts and runs like the powerhouse it is! Never a problem with starting. I have the spring starter on mine. Wind it up once to choke, then again to start. Inverted is the norm, matter of fact never seen one upright in an airplane! Would look kind of goofy!
Put it in inverted and let her fly! |
Engine no care. Gottum spark plug and fuel pump.
Pat, I thought for sure you were going to get on here and tell em they have to start the engine clockwise if they mount it inverted :) Or maybe that they have to hold the plane upside down to start it....the list could go on and on ;)
HI
good to hear no problem inverted-and the norm -TONY |
If you are new to gas engines, may I suggest the spring starter for the G62? It really makes the engine easy to start.
ORIGINAL: Texastbird If you are new to gas engines, may I suggest the spring starter for the G62? It really makes the engine easy to start. |
ORIGINAL: arobatx Pat, I thought for sure you were going to get on here and tell em they have to start the engine clockwise if they mount it inverted :) Or maybe that they have to hold the plane upside down to start it....the list could go on and on ;) |
ORIGINAL: BadAzzMaxx 99.9% of all single cylinder engines are mounted inverted. Milton |
ORIGINAL: edwal07 ORIGINAL: Texastbird If you are new to gas engines, may I suggest the spring starter for the G62? It really makes the engine easy to start. |
ORIGINAL: STUKA BARRY ORIGINAL: edwal07 ORIGINAL: Texastbird If you are new to gas engines, may I suggest the spring starter for the G62? It really makes the engine easy to start. For a newbie it would be nice to have! And then there is an electronic ignition available to update from the coil ignition of which I have not done. If it ain't broke, don't fix it! |
I think folks see others at the field starting their EI engines, with lazy two finger flips, starting at compression. You will fail and likely get bitten back doing this with the oem mag ignition equipped engines. Passing them quickly through compression, with plenty of headstart works fine, as noted above, when properly tuned. I'd spend the time to get to know your engine, and really understand strong tuning techniques. Spend less money and carry less weight too ;)
ORIGINAL: arobatx I think folks see others at the field starting their EI engines, with lazy two finger flips, starting at compression. You will fail and likely get bitten back doing this with the oem mag ignition equipped engines. Passing them quickly through compression, with plenty of headstart works fine, as noted above, when properly tuned. I'd spend the time to get to know your engine, and really understand strong tuning techniques. Spend less money and carry less weight too ;) For the most part, give me an electronic ignition though! |
Wow, I didn't mean to start a war. I was just making a suggestion for someone who may not have any experience with a large magneto engine, and maybe not any help either.
