RE: Pull-Pull on throttle
ORIGINAL: JeffH The only downsides are, current draw and the fact that your servo will not last as long. The motor will always be pulling against the spring. |
ORIGINAL: JeffH I say it will work fine and for a long time. The only downsides are, current draw and the fact that your servo will not last as long. The motor will always be pulling against the spring. What I have had happen multiple times is failure of minature servos when being used on throttles. The brand did not seem to matter, they just do not appear to be strong enough internally to resist the level of vibration found in gas engines. My experience is that excess wear or outright failure will come from vibration well before current draw takes out the throttle servo. |
It could even be argued that the wire method suggested by John would reduce the vibration load on the throttle servo.
The tension on the throttle spring is absolutely minimal. Any decent 5Kg servo will handle that without any difficulty or excessive current draw |
ORIGINAL: Gremlin Castle My experience is that excess wear or outright failure will come from vibration well before current draw takes out the throttle servo. |
I lost a throttle servo back in September. It locked up tight, so the spring would not have helped me at all. I am guessing the motor burnt up and froze. It was a pretty old servo. The worst part was that it stuck in a position that was too fast to land, too slow to fly.... It bunny hopped all the way down the runway to the beanfield, no damage to my 1/4 Scale Wilga other than bent axle.
I disconnect all of my springs, I leave the spring there, just unhook it. |
I have brand new servos on all controls. Best insurance I hope. Capt,n
| All times are GMT -8. The time now is 02:55 PM. |
