RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   RCG 26cc - Anyone using this engine? (https://www.rcuniverse.com/forum/gas-engines-142/10154393-rcg-26cc-anyone-using-engine.html)
WildeOne 11-23-2010 01:04 PM
Planning to buy one and would appreciate any user feedback. Tkx.
VF84sluggo 11-23-2010 01:11 PM
RE: RCG 26cc - Anyone using this engine?
If you mean the RCGF/Aerovate 26cc, I am. It is just past break-in, but so far so good. In fact, the other day one of the buddies at the field commented on how it just fired right up when I put the starter on it...no muss, no fuss. So, again, I don't have many hours on it at all at this point, but it seems ok to me.
Tired Old Man 11-23-2010 02:07 PM
Lot of them out there under various names. Some are working great, some not so great.
VF84sluggo 11-23-2010 02:20 PM
ORIGINAL: Tired Old Man
That's the part that has me a little worried...time will tell, I suppose.
apalsson 11-23-2010 02:36 PM
Jim,
RCG 26cc, RCGF 26cc and Aerovate 26cc are all pretty much the same engine.
If you search this forum for any of those, you will find lengthy discussions about them.
As far as I know, the RCG is the RCGF model sold by Hobby King. Many dealers will claim their RCGF is somehow better or different but in fact, these are all the same basic engine. If you buy one, you will notice the box is the RCGF box and the manual is the one originally done for RCGF and later Aerovate.
In some cases, dealers have had them fitted with genuine Rcexl ignitions and Walbro carburettors to set their models apart from the stanard offering from the factory.
If you are mechanically minded and able to service your own engine, you can get lots of savings by buying these engines but if you are new to gassers, my suggestion is stick with brands with less product flavours and more reliable after sales support.
VF84sluggo 11-23-2010 02:41 PM
ORIGINAL: apalsson
...but if you are new to gassers, my suggestion is stick with brands with less product flavours and more reliable after sales support.
I am, so any recommendations? I ask because my RCGF 26cc is in an ESM .90 P-51 (came as part of the package 'deal'), and Ive been thinking a little more power would be nice, probably a 30cc would be good.
apalsson 11-23-2010 02:53 PM
I'm probably not the best guy to make any recommendations on brands to buy, mainly because I deal in engines so any recommendation from me would be seen as me blowing my own trumpet.
There are many excellent engines out there in this class. If you want to stick with a gasser, MVVS26cc, Evolution26cc, DLE30cc (side carb and rear carb) come to mind.
All good engines and on opposite ends of the budget range.
Then there are the G26 and G20. Also excellent engines that will last a very long time if looked after.
If I keep going, I will probably get the wrath of every engine dealer out there :)
Admittedly, the longer I am involved with gas engines, the more I am a believer that you tend to get what you pay for.
VF84sluggo 11-23-2010 05:13 PM
ORIGINAL: apalsson
Yeah, don't want to get you in trouble or hijack this thread...thanks for the info, I'll investigate from here. I do want to stick with a gasser for my P51.
I do 110% agree that with few execptions, you are correct on the price/quality scale. To paraphrase Gucci, the Italian shoe dude, the sweetness of a low price soon fades, while the bitterness of poor quality long remains.
STUKA BARRY 11-23-2010 05:26 PM
I think I've got one of the variations called the XYZ 26cc. I've been flying it all season long. Its been a pretty good engine with the genuine RcExcell ignition. It will hand start, but it does'nt start right up like a Fox or DA would. The idle is alittle finicky, but it transitions to full throttle with no hesitation and I'm getting 7300RPM's on a Xoar 17X10 prop. It pulls the BUSA 1/4 scale Cub around with some authority, not that a Cub is going to 3D or anything, but I'm pretty happy concidering its a $149.00 engine. Its excellent on fuel too.
pe reivers 11-23-2010 05:45 PM
Value for money seems OK,
I found it to be an aenemic little bugger. But hey, I'm spoiled.
Tired Old Man 11-23-2010 09:28 PM
I'll say you are too;)
About a Cub not doing 3d.... I'll presume you've never seen Hemple fly his 50% or good hands with a Pilot 50% Decathlon. Then you have the World Models 33% Cubs that do a pretty fair job of that too. Not at all scale but when you get tired of watching the paint dry you have the optioon for a change of pace. It's all about power.
Stick2000 11-25-2010 08:31 AM
I have a RCG 26 purchased from Hobby King. The engine runs nice , fast transition
idle's at 1600 rpm. I have it install in my GP Super Stearman and after about 3
gals. of gas it pulls the 14 lbs. plane along well. It's still breaking-in and turns
Xoar 18x6 @ 7800 rpm. The muffler that comes with the engine does a good
job on the noise level. Starts easy runs smooth and for $140.00 I think it's
a good bargin.
Stick2K
VF84sluggo 11-25-2010 10:34 AM
Got a question to y'all running this engine: Do you find that it doesn't take a whole lot of throttle movement to get big power changes? I'm finding it hard to adjust my radio so that my rpm's are spread out through the full range of the throttle stick. Any suggestions?
Stick2000 11-25-2010 11:20 AM
VF84sluggo,
I programed a throttle curve on my radio (10X) and that
took care of the problem. Most gassers shore this trait.
Stick2K
WildeOne 11-25-2010 05:37 PM
What NGK plug do these motors use?
apalsson 11-25-2010 06:23 PM
CM-6
Tired Old Man 11-26-2010 02:09 AM
The throttle issue more than likely stems from how you have the linkage set up. Run a search on gas engine throttle installations.
Stick2000 11-26-2010 07:54 AM
Also remove the short throttle arm and replace with
longer arm. I modified a servo arm to fit the shaft.
Stick2K
XmanB 03-25-2011 01:30 PM
Can anyone tell me what shaft size is on the XYZ 26cc? I want to put an aluminum spinner but am not sure what size adapter to buy. 7x1.0mm, 8x1.0mm, 8x1.25mm?
p61widowrc 11-23-2011 03:21 PM
I want to use this engine on Maxsford's new SPAD. With the engine box, I was able to mount the engine even with the carb on the back. My problem I have is with the muffler that comes with the engine. In order to run the exhaust tube up and connect with a tee fitting to connect to the scale exhaust tubes that come with the kit, the muffler sticks too far forward and will not let the cowl move into position. What I need is a muffler that will mount more to the rear with the exhaust pipe sticking up. Is there an after market manufacture of mufflers? Even a pitts style muffler with a single pipe would or could work, but so far on the internet I can not find this type of manufacture. Can anyone help? Thanks Bob
acerc 11-23-2011 04:28 PM
I have three RCGF engines. Two are the 26cc. One in a waco and one in a cub.The one in the waco has five gallons of gas thru it.
I really like these engines, have never had a problem of anykind. And they start with one flip, idle well and transition good.
Change the throttle arm to the longer one and set up the linkage appropriately. Throttle curves help greatly as well as sub-trim for moving center stick.
Jtec has some great pitts style mufflers with a narrow header. Had to use one on the cub. Works great. RCGF's pitts 1-1/8 header and Jtec's header is 3/4 of an inch. Jtec will also custom build one to your spec's.
And the sparkplug is the only fault I have with the engines. Definately replace with a NGK CM6.
The one I have most broke in is running a 18-10 at 7300rpm. Of course everyones will be different depending on fuel, oil, prop, altitude and so on. Good luck and enjoy.
acerc 11-23-2011 06:56 PM
And I'm no expert but I believe Aerovate is a name KMP gave their RCGF engines. If you want outstanding after purchase service use BP Hobbies. If cost is more important Hobby King is the cheapest but there's no after sale service.
No I do not have any affiliation with any of them. Just a consumer.
TimBle 11-23-2011 10:31 PM
ORIGINAL: VF84sluggo
ORIGINAL: apalsson
There loads of the RCGF26/RCG26/Aerovate26 running around in our town. They're all pretty much reliable as 2 stroke petrol engines go. They're just not very powerful and they're heavy for what they are. The RCGF 20cc is a better engines IMO, as is the DLE 20cc. Getthe timing and needle settings right and either will perform like a 1.20 2stroke glow engine. I've seen a RCGF 20 pull a 6.5kh ESM Spitfire around the sky with the timing retarded and the engine running rich. Not sure what the pilot thought he was doing but each to his own. Tuned right the engine woke up and is a work horse.
You'd do well to replace that engine with one of the 20cc units, either RCGFor DLE. If a 30cc can fit then why the heck not. Warbirds were never underpowered beasts so whyshould a scale model of one be underpowered?
acerc 11-24-2011 01:37 PM
VF84sluggo, If that is the 71" wingspan put a RCGF 32 with a 20-8 prop and you could fly 3D if so desired.
apalsson 11-24-2011 04:50 PM
ORIGINAL: STUKA BARRY
Pretty ordinary, isn't it?
The MVVS 26cc in my 30cc Sbach spins an 18x8 Xoar prop at around 8,000 on the ground with a JTEC Pitts muffler.
The Silent Beauty mufflers are far less restrictive and also provide actual noise reduction
