RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Brison Ignition Module (https://www.rcuniverse.com/forum/gas-engines-142/10269904-brison-ignition-module.html)
All Day Dan 01-17-2011 11:35 AM
1 Attachment(s)
Does anyone know the history of this Brison ignition module? I thought that the Brison engines came with CH ignitions. Who made this one? Dan.
w8ye 01-17-2011 01:10 PM
RE: Brison Ignition Module
Looks like an old one?
Tired Old Man 01-17-2011 03:32 PM
Maybe an early attempt at labeling under the Brison name, or simply replaced a damaged outer case. First I've seen like that. Could also be one they used in the shop when tuning engines.
w8ye 01-17-2011 07:17 PM
This is most likely a throttle coupled spark advance model.
tkg 01-17-2011 08:27 PM
That was made for Brison, its from OK. Gary had "problems" with them and switched to CH. It is a TCSA ignition
They are not serviceable.
Tired Old Man 01-17-2011 08:28 PM
You could almost take that to the bank. It still has the rubber boot and a separate ground strap, which pretty much went away with the syncro spark. I'm sure TKG or BCCHI might chime in soon with more accurate background. I do not believe Gary ever made ignitions, but may have used products from makers other than CH. It's definately not anything late model that might have entered service shortly before the Kangke take over of the company.
All Day Dan 01-17-2011 09:06 PM
It looks like tkg has a good lead. An instruction sheet on the CH website does mention replacing a TCSA with a CH. Now, if we only can find bcchi. Dan.
w8ye 01-17-2011 10:27 PM
Brison engines over the years have had CH ignition units of both the TCSA and automatic advance types depending on when they were made.
bcchi 01-18-2011 11:54 PM
ORIGINAL: DAN REISS
Bill is here but it is a long sad story,too late and to tired to get into this tonight.
BCCHI
