DM-55cc Engine
1 Attachment(s)
Hi
does someone have any experience with this engine? the review on the engine is great i orderd mine today and i will update this forum when it's arrive to me here is some pic and a link to HK thanks ilan http://www.hobbyking.com/hobbyking/s...dProduct=12606 |
RE: DM-55cc Engine
Built assembled and shipped by the company that owns the foundry that makes the actual parts for the "other similar looking engines. There are a number of these that have risen to prominence since a large corporation took a major part in "the original".
Not bad runners, reasonable performance curves, very good price when purchased from HK etc. Check the timing (28 deg BTDC), Check the needle settings (start at 1 3/4 turns open on ech needle), throw away the supplied plug and install a genuine NGK. Enjoy the significant savings you have made by buying it. |
RE: DM-55cc Engine
Keep us posted on how she runs. Is it a genuine walbro
RE: DM-55cc Engine
so if you needed parts for this engine,say piston,crank,rod or reed assembly the dle55 parts would work?
RE: DM-55cc Engine
I hoping the DM-20cc will be along soon.
| All times are GMT -8. The time now is 02:35 AM. |
