RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Engine Problem (https://www.rcuniverse.com/forum/gas-engines-142/10284293-engine-problem.html)
voodoodb 01-24-2011 04:42 AM
Engine Problem
Need Help. I have a RCGF 50cc engine. Idels great, transitions great, but leans out at full throttle after 20-30 seconds. I have richened the HS needle from 1.5 to 3 turns out and it had no effect. I have replumed the tank fittings and lines to a bigger ID. I have put a brand new WT 201 carb on it. (It had a Chinese Walbro copy) Anyone got any ideas? It's a reed valve engine. I have done all I know to.
Doug
Super08 01-24-2011 04:51 AM
RE: Engine Problem
How is your cooling?
w8ye 01-24-2011 04:52 AM
RE: Engine Problem
Did it lean out on you with both carbs?
voodoodb 01-24-2011 05:01 AM
RE: Engine Problem
Cooling is good. It's on a Extra 330L. Top of cylinder hangs out through bottom of cowl. With the Chinese carb, it would sag at full throttle. It ripped at 3/4 throttle all day, but as soon as you advanced it to full it sagged several hundred RPM. That was with a 20x10 prop. I have a 22B vess on it now.
Super08 01-24-2011 05:08 AM
RE: Engine Problem
I wonder if the crankcase is sucking in air somewhere at high rpm causing the mixture to go lean.
aussiesteve 01-24-2011 05:48 AM
RE: Engine Problem
Hey Doug (voodoodb), Long time no speak. Hope all is well with you and yours
Doug (Super08) is pretty much on the mark
Even though I am not supposed to discuss this brand on here, I will tel you where to look on an "Identical" engine ;)
Is it the one you got when you was still in TEDA? I have seen a number of similar problems with them. It is likely one of 3 things.
The front bearing is on its way out
The carb block is leaking
The hub has slipped and the timing is out. (LEast likely as most of them were keyed but I did have a couple of them shear the keys out)
Try the carb block first. They had plastic threads in the insulator block to hold the carbs on in many of them - it is possible the threads have loosened and you need to put in helicoils to tighten up the carb. Also sand the sealing face of the insulator flat.
Lnewqban 01-24-2011 05:49 AM
RE: Engine Problem
Too much air and not enough fuel at full throttle.
Cleaning internal passages-filters or switching to bigger orifice may be?
Weak pump or wrong pressure setting in the regulator?
soarrich 01-24-2011 06:00 AM
RE: Engine Problem
This is how I would troubleshoot your problem:
1. Take the cowl off and run the engine. If the engine doesn't sag after 30 seconds, it's a cooling/baffling problem. If the engine sags after 30 seconds it's something else.
2. Look at your tank, is it sucked in, that would be a venting problem, look for a pinched vent line. To make sure it not a tank/plumbing issue I would get a different tank and hold it right next to the carb and run the engine. If it still sags it's not a tank/plumbing issue.
3. I would try a different fully charged ignition battery, plugging it right into the ignition, no switch. If it still sags I would try another ignition system. If it still sags it's not you ignition.
4. Check the timing of the engine, too far advanced will really make the engine overheat. To check the ignition get a degree wheel or do it with a piece of paper like below, it's something I wrote a while ago, it also tells you how to tune the carb.
The easy no math timing.
Cut a strip of paper 1/4" x 5".
Rap the paper around the prop drive, back by the crankcase where the magnet is. Overlap the paper then cut with a #11 blade cut though both layers of the paper.
Now you have a piece of paper the exact circumference of the prop drive.
Cut it in half, take one of the halves and cut that in half again, take that and cut it in half also. Now cut it so it's in 1/3 and 2/3 pieces.
The 2/3 piece is how much before TDC the engine should fire, (30*).
Now find TDC by removing the spark plug, then sticking something in the hole, a pencil works fine. Move the crankshaft until the piston. is at the top of the cylinder, you'll find that about 5* either side of the TDC it doesn't feel like the piston is moving. Wiggle the crank back and forth until you can find the center of this piston not moving zone, that's TDC.
Now with a marker make a line across the edge of the prop drive onto the crankcase, it doesn't matter where, just that it's easy to see.
Now turn the prop drive clockwise a distance equal to the 2/3 piece of paper.
Plug the ignition into a 4.8v battery, and turn it on.
Now with the two screws loosened move the sensor off the magnet until you hear the ignition pop.
Tighten the screws for the sensor down, then confirm that the timing is still set that 2/3 piece of paper before the TDC mark.
You may have to lengthen one of the grooves in the sensor mount to get the timing correct.
1.Start the engine, set the throttle so the engine is going 3500 rpm.
2.With the engine running I turn the "L" needle in, it is always the needle that is closest to the engine, when the engine speeds up to 4000 rpm I adjust the throttle to bring it back to 3500 rpm. You keep repeating this step until your engine doesn't speed up anymore when you turn the "L" needle in.
3.Turn the "L" needle out 3/16th of a turn.
4.Open the "H" needle 2 turns out, open the throttle all the way open. Now slowly turn the "H" needle in the engine will increase in rpms. Turn the needle about 1/16 at a time, when you get no more increase in rpm the "H" is set properly.
5.Set you idle speed with your throttle trims, it's best to take the idle stop screw completely out, you should have it so the idle is correct with the trim in the middle, and the low trim kills the engine.
6.With the engine running at the idle speed that you fly at you should now be able to snap the throttle open and the engine quickly speed up. If it just dies, turn the "L" needle out 1/16th of a turn, repeat this step until is quickly speeds up. If when you snap the throttle open it stumbles then speeds up turn the "L" needle in 1/16th of a turn until it cleanly and quickly speeds up.
7.Close the hole or notch up in the choke plate, I'll post a picture of what I mean, I do it with soldiering the hole close, some use glue or a bolt.
After you modify the choke plate the way to start the engine is:
a. Close choke completely.
b. Open throttle half way.
c. Flip engine with ignition on until the engine coughs.
d. Take choke fully off.
e. Set throttle just above idle, flip until it starts, usually 3 to 5 flips.
voodoodb 01-24-2011 12:36 PM
RE: Engine Problem
Hey Aussie!! Yes it's the one I got in TEDA. I've about tinkered with it all I am going to. I'll try what you reccomend first. You still in TEDA?
pe reivers 01-24-2011 01:38 PM
RE: Engine Problem
Good post Rich.
My guess is HEAT though, either by lack of cooling, or lean mixture (lack of pumping, leak in seals), or too much advanced ignition, too large a prop, or too much internal friction. (engine failure, build error)
ORIGINAL: soarrich
aussiesteve 01-24-2011 02:57 PM
RE: Engine Problem
I know the plane this engine is in, it has a pretty good cooling setup. With experience on "a very similar brandname and source" of engines, It is more than likely an air leak. That might not be a serial number provided with it - it is a coded "use by" date.
Hey Doug. No, I left TEDA a year or so ago. Still go back from time to time (well - to Xian Shui Gu mostly) to "catch up" with some people. The place has changed a lot but the Wei Ha is still there :D
