RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   DLE 30 3D prop (https://www.rcuniverse.com/forum/gas-engines-142/10300732-dle-30-3d-prop.html)
tripower222 01-30-2011 03:26 PM
DLE 30 3D prop
Anyone used the 18x6w APC prop on the DLE30 and howd ya like it.
JOHNS3D 01-30-2011 03:34 PM
RE: DLE 30 3D prop
put some good propeller, xoar 20x6 or 19x8 you are not using a nitro engine anymore...so forget apc.
w8ye 01-30-2011 03:51 PM
RE: DLE 30 3D prop
As was noted, the DLE 30 needs more prop than the APC 18 X 6W
Also people tend to use Beechwood and not plastic props
The wood props weigh less and tend to break on a ground strike and no damage the engine.
Woody218 01-30-2011 04:07 PM
RE: DLE 30 3D prop
The wood props also let the engine spool up quicker!
All Day Dan 01-30-2011 04:14 PM
RE: DLE 30 3D prop
Try one from these guys. They make great props and can recommend one for your application. dan.
http://www.zingerpropeller.com/
jedijody 01-30-2011 06:34 PM
RE: DLE 30 3D prop
Right after you try a Zinger you'll know why they are mostly used for stiring paint, not flying a large model airplane.
pe reivers 01-31-2011 04:05 AM
RE: DLE 30 3D prop
Zinger has a lowish prop constant, so use a bit more pitch than you are used to. They perform fine then.
Spraytec 06-19-2016 04:53 AM
The Zoar 19 3D-A
