Gas Engine Filters, Where, Which is best?
I have read a lot about gas engine filters, and the importance of filtering more with gas than glow. As I am changing over several planes and new to gas, I am looking for in-line filters that have more filtering capacity. All the filters I look at on Tower or Horizon are Dubro, Hayes, Great Planes, Hangar 9 etc. They either dont say how fine they are, or if they say so its not clear and if they are gas compatible. The finest I can find say 130 microns mesh....what ever that means. I assume the screen size. Do they make filters that are finer, perhaps 150 or 180 microns?
What is everyone using for fine mesh in-line filters for gasoline, so I don't plug up my carb, and where can I get them. Thanks. |
RE: Gas Engine Filters, Where, Which is best?
Bick Bennett at B&B has new clunks w/filters for his gas tanks.
Chris923 |
The inline filters are small and low capacity. I do not use inline filters. The best clunk/tank filters I have found are the Walbro filters from any small gas engine shop. They are felt and will suck the tank dry. I use one in the pickup line in my gas can also. . The Walbro filters are less than $4.00 and readily available. They are available for different fuel tubing sizes, so check what you need before buying one.
Richard |
Walbro clunk filters handle down to 10 microns.
Most of the model airplane inline filters have a 60 mesh screen just like the screen in the Walbro carb
Advance Auto Parts sells a good "felt type" filter which is small enough to fit
most fuel tanks. B&B filter are too large to fit a DuBro type tank but are great for his type tank, which I also use in my larger models. |
1 Attachment(s)
I first posted this picture a few years ago but it's still effective.
Fits most all of the Sullivan and Dubro tank openings and works well up to a couple hundred cc's worth of engine size. Flight use is approaching 400,000 flight hours with numerous engines without generating any issues. 10 micron filtration capability. One in the tank and one in the gas can handles filtering needs about as well as ever needed. About $3.00 at saw and mower shops and better stocked lawn and garden departments. I've led the horse to the water trough. Now it's up to the horse. |
The best thing you can do is filter the fuel in your gas can, then inline filter after your pump going to the airplane. If theres any dirt left after that (usually not) the Walbro screen will catch it. Clean the carb screen twice a year and you'll be just fine. I've been doing this for 25years with excellent results.
You guys are missing the point that the clunk filter will not let the fuel line suck a air bubble.
The surface tension of the fuel and the filter medium will not let a air bubble go through to the fuel line |
for some applications, that is the one and only reason to use a felt clunk filter. Once you start using them, there is no reason left to omit them from a new plane on the bench.</p> I started using felt clunks when having trouble with my glow Spitfire's vibrations and fuel feed to the OS 4-stroke. The felt clunk cured all problems and then some. Never looked back, and even used them on .15 glow engines in aircombat flight.</p> |
A good gas carb can handle up to about an 8" void of fuel in the line before the next influx of fuel is obtained, but rpm stability suffers badly. There is no reason for this when a felt filter only needs to make contact with the fuel to provide a constant fuel supply with virtually zero bubbles in the supply. There is also the fact that a felt filter making only that same basic contact with the fuel will sump nearly 100% of the fuel in the tank before the engine runs out of fuel. With most all other the pick up must be fully immersed in the fuel resevoir to function at all.
However, if some feel a pick up or filter needs to have a fancier appearance to suit their egos they always have the option of using the lower quality products. Eventually they will learn. |
[8D]
The Walbro felt clunk like Ralph posted is all I'll use. Another benefit of them is that they are heavy enough to pull your Tygon tubing down to the bottom of the tank in these smaller tanks. Been using them for 8 or 10 years now in all my gassers and I have NEVER had to clean a carb screen. The felt clunk gets it all. ;)
I buy the chainsaw felt fuel filters from Ace Hardware. I only filter from the gas fuel can. I have had no problems. I use a standard pickup in my tanks.
Porex clunk/filters are better than felt type filters, at same price but some advantages.
Many chainsaws shops are replacing felt filters by porex filters, and now it's difficult to find the felt type. ( here in my country). You can find the best clunk/filter on e-bay ... http://cgi.ebay.es/ws/eBayISAPI.dll?...m=390287846515 When you try one , you will never want to use a felt type anymore. Regards |
I have had sintered type clunks clog up with gum. This never happened with felt filters.
ORIGINAL: Tired Old Man A good gas carb can handle up to about an 8'' void of fuel in the line before the next influx of fuel is obtained, but rpm stability suffers badly. There is no reason for this when a felt filter only needs to make contact with the fuel to provide a constant fuel supply with virtually zero bubbles in the supply. There is also the fact that a felt filter making only that same basic contact with the fuel will sump nearly 100% of the fuel in the tank before the engine runs out of fuel. With most all other the pick up must be fully immersed in the fuel resevoir to function at all. However, if some feel a pick up or filter needs to have a fancier appearance to suit their egos they always have the option of using the lower quality products. Eventually they will learn. Since then, I have not once had to disassemble a carb to clean the screen from gunk and debris which used to be a common occurrence when I used the normal brass clunks I have also noticed when I drain the tanks after a flying day, the felt pickup completely empties the tank. They also have the added benefit that if the pickup momentarily comes out of the fuel in the tank (in high G manouvres etc), there is no noticeable stop to fuel supply to the engine I buy mine from a local Stihl shop and normally keep a few handy on the bench |
There's some good reasons they found a home in UAV operations. When you fly over 1/4 of all the military UAV hours flown in a year you find out what works, and what works best pretty quick. After that you don't fix it if it ain't broken.
ORIGINAL: mpascual Porex clunk/filters are better than felt type filters, at same price but some advantages. Many chainsaws shops are replacing felt filters by porex filters, and now it's difficult to find the felt type. ( here in my country). You can find the best clunk/filter on e-bay ... http://cgi.ebay.es/ws/eBayISAPI.dll?...m=390287846515 When you try one , you will never want to use a felt type anymore. Regards |
how do the ceramic type clunks compare?
The good ones do ok but they need to remain fully immersed in fuel to function correctly.
Thank you for the info on this felt clunk filter. I will be installing it in my gasser. I'm guessing this means I also have to run a 3 line system so I dont put any contaminates on the wrong side of the filter.
1 Attachment(s)
Pe :
Have you tried POREX filters ? (not sinterized) . See specs here : http://www.porex.com/by_product/by_p...fm#javascript; When i discovered this kind of clunk-filters, and after many hours testing , i said : i will NEVER use felt filters. Hundreds of porex filters sold and distributed, and ALL customers agree with me. I have some stock of felt clunks, but i never offer them to modellers. I offer porex filters instead (same price). Also i've found replacement filter screens at very very low price, this filter can be dismantled. The filtering screen is fixed with a G ring. and can be easy changed. Advantages : Same price, can be changed the filtering screen for a fraction of the clunk, constant fuel supply, no bubbles, and NO felt particles on carb screen, more heavy than felt type , special O'ring to avoid bumping inside the tank, ......... Regards |
