RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Engine for 1/7 scale TF P-51? (https://www.rcuniverse.com/forum/gas-engines-142/10522022-engine-1-7-scale-tf-p-51-a.html)
6Sally5 05-15-2011 05:17 PM
I'm building the Top Flite P-51 1/5 scale. I want to put a 4-stroke engine in it (better sound) and a gasser (lower operating costs). Recommendations? Thanks.
w8ye 05-15-2011 05:25 PM
RE: Engine for 1/7 scale TF P-51?
The FG 36 Saito is not really big enough for the 84" Mustang.
6Sally5 05-15-2011 05:40 PM
I have looked at about 20 different YouTube vids...most with different engines. The plans say it's a .90-1.20 for 4-stroke. I've heard the Saito 1.25 is a good engine but really don't know anything about it or any others. Up til now, I have been flying electrics, so I'm "fuel dumb" lol.
Tired Old Man 05-15-2011 06:04 PM
Saito makes extremely good 4 strokes.
w8ye 05-15-2011 06:16 PM
50-60cc would be about right for this plane
REQUIRES: Engine: 2.1 -2.8 cu in (34.5 - 46cc) 2-stroke OR 2.5 -4.3 cu in (41-70 cc) spark ignition gasoline engine Muffler: Pitts style Radio: 5 - 7 channel Servos: 10-11 Standard (2-Aileron, 2-Elevator, 1-Throttle, 1-Rudder, 2-Flaps, 1-Tail Steering, 1-Air Control Valve) (a high torque servo is suggested for the rudder, but not required) Servo Extensions: (2) 24" Extension, (1) Dual Servo Extension (4) 6" Extensions Y-Harness: (1) Y-harness for flaps Misc. Items: Glow plug, 1/4" foam rubber padding, medium fuel tubing, fuel filter, propeller, building and field equipment.</p>
SPECS: Wingspan: 84.5" (2146mm) Wing Area: 1245 sq in (80.3 sq dm) Weight: 19 - 24 lbs (8.61 - 10.88kg) Wing Loading: 32 - 35 oz/sq ft (98 - 107 g/sq dm) Length: 73.5" (1865mm)</p>
6Sally5 05-15-2011 06:45 PM
55cc seems kinda large? recommendations are 1.20 ci max = 30cc.
rstearman 05-15-2011 06:58 PM
In your title you typed 1/7 but in your message you typed 1/5. I think it's causing a little confusing
If it's a 60 size (1/7) a FG36 Saito will work. I have a couple 1/7 mustangs and I'm running YS110s, they sound awesome and they are little rockets.
w8ye 05-15-2011 07:17 PM
There are a lot of the 1/7 Mustangs flying with the Saito FG-20's
rc34074 05-16-2011 05:18 AM
The DLE20 would be a good choice for the 1/7 scale Top Flite - for a muffler get the Jtec small muffler for the DLE20. Its a gas engine but in my opinion it sounds better than the saito 4 strokes. Plus its a lot cheaper and uses cheaper gasoline fuel.
Ed
w8ye 05-16-2011 05:28 AM
The DLE 20 has a lot more opower than the Saito FG-20 and is a lot less trouble
6Sally5 05-18-2011 12:58 PM
Whoops guys..my mistake! You're right, rstearman...I mixed it up. It is a 1/7 scale TF P-51. I just read about a guy's problems with the the FG 20 and he returned it. This is why I'm really checking with experience first! I definitely want a 4stroke, gasser.
6Sally5 05-18-2011 01:00 PM
I don't want a muffler sticking out the side of the plane, but am not familiar with the Jtec...I'll check it out. Pitts style would be fine, and Keleo would really be cool.
