Evolution radial engine?
A 7 cylinder, gasoline radial from Evolution engines. Perfect size for those CARF warbirds...
http://www.horizonhobby.com/Products...rodID=EVOE7260 Jesse |
RE: Evolution radial engine?
Looks cool.[8D]
They may actually sell one here if the decimal moves to the left.
It's about $800 cheaper than the best selling one, (RCS by Moki), in the same displacement class, so it might sell well if the quality and reliability is there. This one's made in India, so only time will tell if it's a good one.
Jesse |
Has any body tried the 35 cc 7 cyl. Engine?
I have the 77cc 7 cylinder in glow. It runs fantastic! The sound is to die for!
My review is on the Horizon site. Tim |
I'll bet something like that would sound awesome on the nose of a 3D plane while hovering?
Sorry, the thought crossed my mind and I couldn't resist.... |
What plane do you have it mounted on?.
The engine is still on the test stand. The breakin takes about four hours of run time according to the manual and that seems about right. When new the engine is very tight and needs to be carefully broken in. It started right up but it must stay at a high idle speed to keep running. I have about 3 1/2 hours on it now and it is now running on the flight mix of fuel which is a gallon of standard four cycle fuel mixed with a gallon of methanol. Actually pretty cheap fuel mix.
I'm using a Electro Dynamics glow driver that works really well to light up the seven glow plugs. |
What is the rate of fuel consumption?
The Evolution 260 Gas Radial will not fit in the CARF warbirds, only the Moki's, and those just barely!
Tom |
Originally Posted by Speedy-Gonzales
(Post 11717742)
The engine runs fantastic. Here is the build link that has the test flight video. Sorry for the poor camera work but my volunteers had never used a video camera before. http://www.***********s.com/forums/s...t=87710&page=9 |
Whatis the firing order of Evo 7-77?
| All times are GMT -8. The time now is 05:12 AM. |
