RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Spring in DLE plug cap (https://www.rcuniverse.com/forum/gas-engines-142/10610683-spring-dle-plug-cap.html)
Ttaylor63 07-07-2011 02:38 PM
Is it necessary to run the spring in plug cap & whats the purpose of it.... Will it harm anything if u don't run it. I had a DLE 20 that i didn't run the spring in & never had any problems....Just curious is all...
I stripped my threads in my cylinder today on my DLE 30.. Installed a Smart Fly system & could'nt get to run at all. Had power coming from the smart fly ignition lead & also had spark inside plug cap when magnet went by, but it would'nt even pop. I had a 42% system in it before & had a wild hare to change out & now this....Wishing now i woulda left good enuf alone....I'am sending the cylinder off the C.F. Lee to get fixed.. I called all over town looking for a 10mm x 1.0 mm helicoil & didnt have any luck. Mr. Lee charges $15.00 to repair & that includes return shipping. I also went ahead & ordered a new cylinder from Tower....
Tired Old Man 07-07-2011 03:13 PM
RE: Spring in DLE plug cap
I'n not going to say it[:@]
If the cap is on tight the spring is not needed. Seems a lot of people need it though. It acts as a ground guarantee for the limp wristed.
If the cap had spark the ignition was not the reason for not running. Try fuel next.
captinjohn 07-07-2011 06:11 PM
You should like the Heli coil threads better. Just do not over tighten the sparkplug.Snug should be OK. Capt,n
