RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   BME 95 cc engine (https://www.rcuniverse.com/forum/gas-engines-142/10659843-bme-95-cc-engine.html)
kellyca 08-07-2011 12:19 PM
BME 95 cc engine
I have a BME 95 cc engine that need the reeds replaced. Does anyone know where I can get a set? Are there other reed sets that will work in this engine. It is good engine and I hate to put it on the shelf... Thanks
Tired Old Man 08-07-2011 01:51 PM
RE: BME 95 cc engine
Have you considered calling BME? That would be the first thing I would do if it were mine.
All Day Dan 08-07-2011 02:42 PM
Kelly, see if these guys can help. Dan.
http://bmeengine.com/
kellyca 08-07-2011 05:31 PM
Thanks guys, I will check them out. I had read they had went out of business.
Tired Old Man 08-07-2011 06:37 PM
New owners about 3 years ago, and definately still in business. Worst come to worst you could probaly adapt the reeds from the cage of a DA 100, but withou seeing your reeds I couldn't guarantee that. In that size engine there has been a lot of parts commonality. The reeds from a BME 102, 105, and 110 may also fit.
kellyca 08-09-2011 04:23 PM
1 Attachment(s)
Update: Waiting for reply back from BME. I called and spoke to Tom and also sent him pictures of my engine.
apalsson 08-09-2011 04:25 PM
You may want to reconsider the throttle linkage
kellyca 08-09-2011 04:35 PM
That is the rod I use for the choke. It hangs out the bottom of the cowl on my hanger 9 Sukhoi. No issues with it. Problem is the reed is broke
apalsson 08-09-2011 04:45 PM
It was the snap-on ball link I spotted there and the z-bend metal rod.
It's hard to see from the photo if it attaches to the throttle butterfly or the choke.
Either way, there are better ways
No offense meant
All Day Dan 08-09-2011 04:50 PM
That Z bend will eventually wear out the hole in the choke lever due to vibration and differenece in materials you have there. Use a more positive connection like a swivel or ball link. Also, secure the end end you are pulling on. You can't leave it rattling around. Dan.
kellyca 08-09-2011 05:39 PM
No offence taken. You are right there are better ways. I will change it if I can locate new reeds and get it back running.
Always open to suggestions
kellyca 08-19-2011 02:27 PM
Talked to TOM at BME.....No reeds yet..
I am still looking for somthing that will work....carbon fiber maybe???
Tired Old Man 08-19-2011 03:33 PM
Don't do that unless you have a few sets for later replacement. Carbon reeds work great in applications that have a reed shock stop, but not over direct metal contact. Take a look at the reeds in a DA 100 or DLE 111 and see if they can be adapted to fit your cage. Might even compare to a 3w 106. Pop the reeds out of one cage and insert into the other.
kellyca 09-15-2011 04:07 PM
Finally got 2 reeds from Tom at BME. Engine is running. Still looking for back up material to make my own.
