technical issues
Hi all,
I believe our hobby has a specific technical character and many of what is written down on this forum is about technical issues. What you get is a mass of contradictions about methods, oil percentages, rpm's, needle settings.. you name it. I can imagine that people who want to expose their problem here hoping to find a direct solution many times get more confused as they were before. For instance, a (apparently) simple system as a single-cil combustion engine seems to behave differently in (apparantly) similar circumstances. Note however that due to tolerances no engine is similar even if same type and brand and tight tolerances cost money and money..we don't have. No circumstance is similar, airpressure/ moisture , prop type, gas/oil mixture and brand, exhaust.... The popular Walbro carburetter seems to be very sensitive to surrounding airpressure and is a major cause of weird behaviour of the engine in flying conditions. When will there be a computer driven injection system? The proposed cure's and methods might work for some and not for others and this is what we encounter througout the forum. Statistics many times provide for strong indications of this or that has a fair chance to fit reality for instance the forum about the GF42i wich massively states the poor quality of the engine. However statistic reliability requires major amounts of responses (wich is the case in the above thread). Jugements of sounds, vibrations and even power differ from person to person and is difficult to rely on. Country culture's cause different experiences and makes people put energy in different fields of the hobby wich shifts the gravity of knowledge to other issues for instance noise and the related vibration. Well you've been needing some linguistic souplesse to understand my international English but what I try to say is that in many cases it isn't all that simple to derivate the direct cure for your problem. Reading the concerning threads although is extremely interesting because it contains the actual stuff to synthesise the cure for your problem. |
RE: technical issues
Huh?
I think he has a problem with his throat. what did he say?????:D:D:D:D:D:D:D:D:D
I think he said nobody knows what they are talking about because nothing is standardized.
I think he said he said:
...what I try to say is that in many cases it isn't all that simple to derivate the direct cure for your problem. Reading the concerning threads although is extremely interesting because it contains the actual stuff to synthesise the cure for your problem. [8D] |
He would make great Politician.
ORIGINAL: Super08 He would make great Politician. Ameyam |
Would not all of that be summed up with three or four letter's. IMO or IMHO
ORIGINAL: cuwaert What you get is a mass of contradictions about methods, oil percentages, rpm's, needle settings.. you name it. I can imagine that people who want to expose their problem here hoping to find a direct solution many times get more confused as they were before. "If you're not confused, you're not paying attention." Tom Peters :) |
I understood him as clear as mud....he said blah blah yada yada #$%^*& .god that was easy!gessh jodi its just plain english lol.
technically speaking, he is right of course, there never was an issue, but now there is
Guys you are all going about this wrong. You have to be of the same mind set to understand it obviously! Tonight after your favorite libation or 3, come back and read it. I bet it will make perfect since!:D:D I do it all the time and then the next day reread an email or FB post I sent and go what was I trying to say!:)
I think he's saying that there are a lot of factors in running a gas engine and no one solution fits all. I agree - much like weather predictions, nothing is going to be completely correct for everyone.
But filter the information and what's left; is good [8D] |
Dang, I sense some Rocket Science here guys!
I searched forums about a GF42i and found the op's post the only reference to that number. So what is that suppose to be?
The actual question he seemed to pose is "When will there be a computer driven fuel injected gas engine"? The Pamster |
He is telling us how to survive in this hobby, in real doing-it sense (not on paper). I agree with him.
Ok, I perused once more and concur, I cognise a jiff more subsequently. But only a jiff:)
Wish people would write in plain english so I dont have to use the Thesauraus more often Ameyam |
You;re being tricky..:) i don't think my thesauraus lists the word jiff?
I seem to sense he would like a seperate sticky thread written by the knowledgeable like T.O.M and Jedi etc on a few common topics so we don't have to sift through a lot of dribble to get the answer we need.
The new to gas engines sticky is great but a few more specific ones would be good. Sometimes threads can drift off topic and have heaps of different opinions. Stickys made by the "masters" would be a good (quick) reference. Regards Mark |
<font size="4">If this were a cookie cutter hobby, we'd all be out there flying a yellow cub with a 2 cell battery and a 3 channel am radio! What makes it interesting is the variety and diversity of each aircraft and their independent characteristics in flight.
I'm going to go eat my cookie Cub now before I start to sound like that first post. (what did he say anyway?)</font> |
Dang! We don't often see such high-falutin' ideas/words on RCU. (By the way - you mispelled "wich" - should have been "which").
I think you will learn more with flying the thing well than just flying it. How many of us have the guts/time/energy/patience to fly IMAC/pattern on a daily basis?
The learning space in is hobby is quite big and we may not have time in our life to cover it all. |
In summary problems don't really exist until we try to solve them
Or a goal that we try to achieve it.
Isn't the European Union headquartered in Belguim, where the OP is from? Explains a lot.:D
| All times are GMT -8. The time now is 07:38 AM. |
