Piston and cylinder length
Hello all
For a single cylinder 1" bore X 1.5" stroke 4 cycle low compression engine Is there a formula to determine the length of the piston, the length of the cylinder and the length of crank rod? Is 6:1 a good low compression ratio? Also for example, does it matter if the bottom edge of piston is .125" above the bottom edge of the cylinder vs .25" above? Or even does it matter if the bottom edge of the piston is .125" or .25" below the bottom edge of the cylinder? Thanks Borna |
RE: Piston and cylinder length
talking about opening a can of worms,
