RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Does anyone recognize this Sachs conversion?? (https://www.rcuniverse.com/forum/gas-engines-142/1090046-does-anyone-recognize-sachs-conversion.html)
TLH101 08-26-2003 02:51 AM
1 Attachment(s)
I know it is a 4.2, but need more info on builder. It has an aluminum colored case and a Sachs crank. The rear of the case has been relieved and there is no provosion for a smoke tap. Also, the prop adapter has a threads on the inside, and a dimple machined into the end of the crank. Has a C&H spark-coupled ignition system.
TLH101 08-26-2003 02:53 AM
1 Attachment(s)
here is another pic:
TLH101 08-26-2003 02:54 AM
1 Attachment(s)
one more pic:
tkg 08-26-2003 03:08 AM
Sachs
Its a Bryons 4.2. They were made by A&M or some by Planes +.
TLH101 08-26-2003 03:16 AM
Thanks for the quick info. I had a suspicion that may be what it is. Has a lot of the old A&M traits(sure glad it has a Sachs crank), but that prop hub threw me. I guess that is for the scale props Byron had?
Antique 08-26-2003 04:32 AM
The threads in the hub are for the puller used to take the 2 blade prop hub off to use the Byron 3 blade prop....
