clean engine
What's the most effective way to clean the exterior of the engine. Soak in some solution, then scrub with old toothbrush??Thanks!!
clean engine
Fill an old crock pot with Ethylene Glycol anti-freeze, cook for a few hours, come out clean....
clean engine
bead blast it clean
clean engine
Jim:
The crock pot and anti-freeze methods works very well. Use low heat (high heat can discolor aluminum). I have also used heavy-duty paint and varnish remover and had success with that method. Stuff is toxic so you need to be careful there. Hey, you coming to our Labor Day "Buy-and-Fly" Swap Meet??? Dan |
clean engine
Hey guys .. thanks for the tips. I'll try to make the fly in, Dan. Sounds great! I'd like to meet some of the AMT guys anyway. Jim
| All times are GMT -8. The time now is 08:26 AM. |
